Timing in SPIN
The following code snippet is obviously flawed. How is this fixed in SPIN without using something clunky like WAITCNT, that doesn't let the cog do anything else until the timed interval is up?
temp := 10_000_000 + cnt repeat if cnt => temp temp += 10_000_000 (do stuff) (do other stuff)
The correct way is to compare a difference, as in This will work so long as the delay is less than 2^31
