Retriggering TRIACs
I am driving one of these : http://www.futurlec.com/SSRAC.shtml
with a propeller based board. Any channel is enabled whenever a logic zero is put on to the channel's control line. That behvavior is already demonstrable (control the output channel on the board, no loads are attached yet).
When I connect the loads to each channel (a 90 Watt flood), will the lamp "go out" when the AC crosses zero?
And if that is true, In order to keep the 120 VAC flowing, should I:
Send a pulse-train to the channel control line to keep the triac triggered?
If I don't care about switching noise and or the phase synch of the pulse train, does it matter if I enable/disable the control line completly out of synch with the zero crossing of the AC?
Any advise that anyone has would be greatly appreciated.
Thanks in advance
Thanks in advance
A schematic would be helpful. One might use some logic chips and opto-isolation to provide a 60 cycle source and that would somewhere be included.
The sync stuff is only for fading and the like.
The 200Hz idea will result in harmonic generation (broadcast.)
Tracy Allen seems to offer a better solution.
Thanks again!
Hey! Is this for the Bear detector you showed me at UPEW?
In most cases boards like this use a ULN chip or individual transistors to drive the leds in the optoisolators. The optoisolator is a triac output, and the only circuitry between the optotriac and the gate of the power triac is a small capacitor. Can't be absolutely sure that is the case for this board but it certainly looks like it. If that is the case it should be possible to trigger the triac at any point in the ac cycle by powering the led at the appropriate time.
