S2 versus Scribbler using Java/C++/Python
I received a few S2's for academic purposes and would like to integrate the robot into a programming class. I want to use a language that the students would likely use outside of robotics. Is the S2 also programmable in multiple languages like Java/C++/Python?
I googled a bit but I don't see a lot of information on other languages for the newer model, and wanted to know where to look for this kind of information.
John Abshier
One of the design goals for S2 was backward compatablity with the Scribbler (the Blue one). The Scibbler was used by the IPRE using a device that plugged into the Serial Port called an IPRE Fluke. It was a card with a camera, sensors and a bluetooth device. Slave software was loaded on the Scribbler. Then, using a PC with bluetooth, software was written on the PC in Python and instructions sent to the slave Scribbler. The IPRE Fluke was sold at a time on Amazon.com
The S2 is designed to work in this system, though I do not know if the slave software has been written for the S2 yet. Check it out here -http://wiki.roboteducation.org/Myro_Hardware and http://www.roboteducation.org/
If it isn't ready now, it should be soon. Ken Gracey may have more info.
Edit - This is the system that John describes above - I had not heard of Better Bots.
