Soldering 1.5mm pitch pins
Hello there,
I have a casual soldering gun (or pencil) and did quite ok with those 2.54mm pitch pins (the usual, DIP ones).
However, I have ordered some Bluetooth to Serial modules, and they are 1.5mm pitch, instead of the 0.1" ones.
Should I need a finer soldering tip, or with the soldering braid?
I see. Hmm, but getting the Metcal Soldering Station here in SE Asia isn't easy. The nearest product I could get now is the SLD-936 (Hakko clone) soldering station.
I may find some fine Hakko compatible tips for that.
Thanks for the suggestion though - the Metcal is really good, but can't really find it in local stores. All they stocked are those Hakko clones.
I believe, the size of the soldering tips are measured as the pitch size? That means, if I need to solder the 1.5mm header, I will need to get the 1.5mm diameter tips?
I see. Hmm, I will show you the bluetooth modules I'm ordering now. It's in http://www.sureelectronics.net/goods.php?id=402. The pins are 1.5mm, and the holes are only semicircular.
So those stuff requires controlled temperature during soldering?
Are you sure it has pins? It looks more like a surface-mount device, like most similar ones I've seen.
I bought a soldering iron station from Elenco that takes a 1/64th of an inch tip. I'm still assembling part of the kit that regulates heat but it was the cheapest I could find. It is basically a 40W soldering iron that plugs into a station.
I think the size of your soldering wire also matters when soldering small stuff.
So what is the optimal temperature should I need to solder SMD parts? And could I use a smaller 0.8mm solder instead of 1mm? Thanks.
You need thinner solder for SMD parts, of course. It depends on the size.
