three pole buzzer
When taking anything apart, you have really almost no idea of whaty you will find. when taking apart a microwave I found a VFD display and also a wierd buzzer. it is a piezo buzzer with three leads! When checking the circuitry around the buzzer, I got only more confused. One lead went to ground (as indicated by the silkscreen), one lead went to the emitter of a transistor, and the third went to the base of that same transistor! Can somebody please tell me how to hook this buxxer to a BS2 please.
One rule of thumb is to apply as low a voltage as you can to get results. And another is to get the polarity right. Reverse polarity and over-voltage are the two foremost reasons for destruction of any device - known or unknown.
http://www.puiaudio.com/pdf/AT-2428-TWT-R.pdf
Seriously though, Forrest Mims provided a driver that was generically accepted as a standard. (See attached)
And along the same lines, it's NU-CLEE-UHR, not NU-KYEW-LUR !
ps: Forrest Mims still ROCKS! http://www.forrestmims.com
pie as in apple pie
and Zo as in Zoey
Hey, that's what it looks like pie-zo :-)
Go Directly To Jail, Do Not Pass GO, Do Not Collect $200!
http://en.wikipedia.org/wiki/Piezoelectricity
'p' ... 'p' in pie
'i' ... 'y' in happy
'ie' ... long 'a' in base
'z' ... 'z' in Zion
'o' ... 'o' in Bode
Then I quite properly blew his mind telling him that the same principle powers those spring-loaded sparkers that start your propane barbeque grill.
By this do you mean that the output frequency is a constant frequency? Is there a circuit where a Micro (like a BS2) could control the tone of the buzzer?
Middle plate ---->|---- Ground Plate ----|<---- smallest plate
"Is there a circuit where a Micro (like a BS2) could control the tone of the buzzer?" - yes, just use the ground plate and the Middle plate as if it were a two wire element. If you want you can merge the small and medium plate as if it's a single plate.
