A few questions about the Propeller and a product I sell.
I had designed a product which I sell using the SX28 chip but now that it is at EOL, I am needing to redesign all over again. The main concern I have is the size of the Prop DIP. The Prop chip is almost as big as the board I am currently using. I have seen the 44 pin surface mount chip which is way smaller and am wondering if it is even possible to hand solder all the leads without burning out the chip.
Another question I have is...Is there a pre-manufactured IC chip that can read a square wave RPM signal from a vehicle and output a readable signal for the Propeller? I would like to offer an extra plug and play device that connects to the product currently using the SX chip and having a small box that just plugs in would be great!
And last but not least.. Is there a difference in current handling between the small surface mount components and through hole components like resistors, diodes, transistors, and caps? I know they are still 1/2 watt, but I worry about heat. The current design has no heat and is very reliable / stable. Two years and counting on my current design thanks to some on this forum!
Thanks for any help!!
You need to calculate the power used by resistors, before switching to surface-mount parts, if you are worried about power ratings. They can't handle anything like the same dissipation. It depends on the size, of course. I mainly use 0805 parts - 0.1W.
Most of the pins have solder bridges after the first pass with the solder and soldering iron. The trick that makes hand soldering possible is cleaning up the extra solder with solder wick.
I haven't damaged any chips I've soldered. I just use lead solder. I suppose lead free solder might need more heat but I still doubt you'd damage the chips.
Duane
I hear the real way to do this effectively is with a stencil and a toaster oven, although I've not tried that technique.
I almost exclusively use smt resistors. They are so nice and small; the 0603 size fit nicely between 0.1" holes. I just use my normal soldering iron.
For one or two of a board I really like www.batchpcb.com prices and quality are great though it takes a while for boards to arrive. I use www.4pcb.com BareBones deal for when I need prototypes fast. (the 4pcb deal always costs >$60) The 4pcb "$33 each" deal is also nice for small production runs if you panelise and cut apart the circuits yourself.
Lawson
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/568/Default.aspx
I soldered the entire board together in 1 hour, no errors. It will give you confidence for SMD devices. I now solder 0805 and 0602 and QFP components all the time.
A good soldering iron or station is a must.
Yes you can hand solder the sm Propeller chip...but why? Get a hot air station..they are really
inexpensive now. It will only take you an hour or so to get good at soldering a prop to a board. You
will always be glad you got a hot air station as they are so useful. If you need help finding a bargain
just ask here...60.00 USD should buy you one, 20.00 USD more for one with a soldering iron attached.
The Prop should have no problem at all detecting and counting a square wave signal, I guess RPM
means revolutions/min ? I see no need for an extra IC to do this. The prop has 8 processors so you
can dedicate one to simply counting the square wave and placing the results into ram for the other
processors to read. Once this is done you don't need to think about it any more, the count will always
be there in ram waiting to be used.
The sm Prop is rated the same as the DIP part is.
As for the other parts why not just stay with through hole parts for them?
Just get a new board made that has pads for the sm prop and holes for
regular resistors, caps..etc
See this thread for info on getting new boards made up for about 1.40 USD
and that includes shipping :-)
http://forums.parallax.com/showthread.php?131974-Really-really-really-cheap-PC-boards!
Oh, I find it easiest to solder the large ICs to the board first.
After you have through hole parts on the board it's much harder
to solder something like a sm prop close to them. When your
boards come in just solder a prop on each of them and then it will
be easy to add the other parts later.
For dev work, consider breadboarding the dip40 prop.
Enjoy :-)
*Edit*
Interesting enough, both of my vendors I use to order parts through don't offer surface mount components....any suggestions?
I use an aoyue 852++, a cheap chinese hot air iron, and the only problem I ever had with burning up anything was soldering plastic SMD header sockets for an xbee. I now use through-hole sockets, the SMD sockets were way too much trouble. Traditional SMD devices (ICs, resistors, etc) are no problem whatsoever. You'd have to be fairly negligent to seriously damage a component or delaminate a board.
Using the small tip, you get pretty good control of where the heat is going. Generally you have controls for both air flow and temperature.
For easy practice, grab old computer PCBs from your junk bin. My initial learning experiences involved destroying and putting back together some old netgear ethernet cards. Every computer guy has a pile of obsolete expansion cards.
Another real handy thing to have is an inexpensive stereomicroscope (for example, amscope.com). Such a thing has come in handy for inspecting both through-hole and especially SMD work, as my eyes continue to age. I look back fondly at the days when I could solder boards with no magnifier, just looking at them...
EDIT - for vendors, I often use jameco, digikey, or newark. I find Jameco's catalogs to be just the right balance to get a good overview of components available without getting into too much detail or an overwhelming selection of the parts. All three of them have decent website search capabilities to find what you need.
That's what everyone, including me, thinks before they get a hot air station
and get some practice time. Solder the sm chip onto the boards first is what
I recommend.
For parts I recommend buying from ebay sellers in Thailand, ML China, Tiawan
or Hong Kong. I just got a sack of 500 3.6V Zeners (thru hole) for 9.90 USD
and that included shipping. If I bought them local here in Israel it would have cost
several times that much. I really didn't need 500 but it was so cheap and I figured
I would need them someday.
One really nice place to get parts is www.taydaelectronics.com -- great prices, fast
and cheap shipping and they take paypal. SM resistors are less than a penny and
thru hole are one penny each...for example. When buying in bulk you can do better
from ebay sellers but Tayda is great for buying smaller quantities.. I buy 3v3 regulators
there for .18ea for the TO-92 type and .24ea for the 1.5amp LM317T (I use these for
3v3)
If you post a list of the components used on your board maybe I can direct you to
some good sources for those parts...many others here on the forum are also great
bargain hunters and may know good sources.
A hot air rework system doesn't heat the whole area, the tips are fitted with shields that stop adjacent parts from being unsoldered.
