three pole buzzer — Parallax Forums
three pole buzzer
bomberbomber Posts: 297
edited 2011-06-05 09:54 in General Discussion
When taking anything apart, you have really almost no idea of whaty you will find. when taking apart a microwave I found a VFD display and also a wierd buzzer. it is a piezo buzzer with three leads! When checking the circuitry around the buzzer, I got only more confused. One lead went to ground (as indicated by the silkscreen), one lead went to the emitter of a transistor, and the third went to the base of that same transistor! Can somebody please tell me how to hook this buxxer to a BS2 please.
    edited 2011-06-04 07:37
    A part number, picture, schematic or model of the microwave might help. Do you know the voltage that should be feeding it?
  • bomberbomber Posts: 297
    edited 2011-06-04 08:11
    The buzzer was on the low voltage circuit board. My guess is between 3 and 12V feeding the buzzer. As far as pictures..
    1024 x 768 - 120K
    1024 x 768 - 99K
    edited 2011-06-04 08:38
    The truth about hacking for parts is that you have a high risk that nothing will come of it. At times, all you can do is apply limited power to something and see if it works. The buzzer may work fine at 3 volt with two of the leads. It is hard to guess what the third wire that is attached to the base might be doing as this configuration is rather non-standard for generic parts.
    One rule of thumb is to apply as low a voltage as you can to get results. And another is to get the polarity right. Reverse polarity and over-voltage are the two foremost reasons for destruction of any device - known or unknown.
  • wasswass Posts: 151
    edited 2011-06-04 08:40
    Here's an example of just such a device with a small sample schematic showing its use.
    http://www.puiaudio.com/pdf/AT-2428-TWT-R.pdf
    edited 2011-06-04 11:48
    wass, the schematic is almost identical to the board layout. thank you.
    edited 2011-06-04 14:51
    Back in my day ... piezo's only had three wires.. and we had to build our own self resonant piezo transistor drivers to make them work. :-)
    Seriously though, Forrest Mims provided a driver that was generically accepted as a standard. (See attached)
    1024 x 744 - 189K
    edited 2011-06-04 15:37
    Two wires, three wires, it really doesn't matter. The main thing is to say piezo properly. It's PEE-YAY-ZOH, not PEE-ZEE-OH.
    And along the same lines, it's NU-CLEE-UHR, not NU-KYEW-LUR !
    ps: Forrest Mims still ROCKS! http://www.forrestmims.com
    edited 2011-06-04 16:08
    I say piezo like
    pie as in apple pie
    and Zo as in Zoey
    Hey, that's what it looks like pie-zo :-)
    edited 2011-06-04 16:11
    OMG.
    Go Directly To Jail, Do Not Pass GO, Do Not Collect $200!
    edited 2011-06-04 17:00
    Apparently today I'm easily entertained ... :-) ... Erco is correct (PEE-YAY-ZOH)
    http://en.wikipedia.org/wiki/Piezoelectricity
    'p' ... 'p' in pie
    'i' ... 'y' in happy
    'ie' ... long 'a' in base
    'z' ... 'z' in Zion
    'o' ... 'o' in Bode
    edited 2011-06-04 17:39
    I was telling one of our younger techs (early 20's, worked in a hardware store for a few years so quite sharp on mechanical stuff) how a Barantec touch switch worked, and when I said the word "piezoelectric" he had no idea what I was talking about.
    Then I quite properly blew his mind telling him that the same principle powers those spring-loaded sparkers that start your propane barbeque grill.
    edited 2011-06-05 08:21
    By this do you mean that the output frequency is a constant frequency? Is there a circuit where a Micro (like a BS2) could control the tone of the buzzer?
    edited 2011-06-05 09:29
    "self resonant piezo transistor drivers" ... "By this do you mean that the output frequency is a constant frequency" ... yes, one of the three wires is part of a mechanical feedback loop which maintains a constant frequency determined by the crystal itself. Size, temperature and mechanical load characteristics can alter the resonant effects. The largest plate (bottom plate) is usually the ground. The middle sized plate is what you drive the piezo with, the smallest plate is the feedback and is on the same plane and polarity as the middle sized plate. Because of the nature of the crystal and how the polarities interact, the smallest plate and the middle plate are electrically isolated as if they are two back to back series diodes only coupled by a small amount of fringe capacitance.
    Middle plate ---->|---- Ground Plate ----|<---- smallest plate
    "Is there a circuit where a Micro (like a BS2) could control the tone of the buzzer?" - yes, just use the ground plate and the Middle plate as if it were a two wire element. If you want you can merge the small and medium plate as if it's a single plate.
    Thank you everybody who anwsered!! I have offically titled this solved!
