$100K Jetpack Flies to 5000 ft.
http://www.rdmag.com/News/2011/06/Industries-Aerospace-Engineering-Modern-day-jetpack-takes-flight/
They HOPE to reduce the cost to $100K/unit.
Risky to operate, but at least it's expensive. I'll stick with my Cessna for now.
The article/video did not state normal flight time, so I wonder what the MPG might be.
It was interesting that the inventor's name is the same as the famous American aviation pioneer, Glenn L. Martin.
-phar
http://en.wikipedia.org/wiki/Moller_Skycar_M400
It is a small ducted fan VTOL.
Rich H
prof_braino, the Earth is 315,689,645,825,135,283,408,314.8694358 square feet. Assuming a person takes up 2 square feet and a short range air craft will only fly over the 1/3 that is land. I'd put the odds of one falling on you at roughly 1 in 52,614,940,970,855,880,568,052.4782393. If you never intend to go to Antarctica or Greenland we nudge the odds up a scooch.
Although I imagine the odds of it falling on someone are much higher.
With a jet, the blades 'are' the engine, in a self perpetuating combustion pressure chamber.
With a gas engine driving the blades there is a longer drive train if you will and there are several more engine cycles.
It all comes down to application efficiency, and for this application, I personally think a jet engine would outperform the current implementation if it were matched properly.
http://www.theregister.co.uk/2008/05/15/swiss_birdman_backpack_jet_stunt/
Used what looks like four of these
http://www.jetcatusa.com/p200.html
-dan
Modern turbofan engines gain efficiency over the old turbojets by using their power to turn large fans rather than ejecting the exhaust at high speed. Only a small portion of the thrust is from the "jet", most is from the high bypass fans.
Ducted fans are far less efficient that an open propeller, but propeller driven aircraft cannot go nearly as fast as jets due to the limitation on how fast an open blade can spin. The blade tips need to stay under the speed of sound.
An Allison 250 or similar turboshaft engine (driving the fans through a transmission) may be a good match for this sort of vehicle but I have to strongly disagree that a pure jet engine would work well in this application.
Rich H
-phar
