Meet RoboProp - an advanced Propeller based robot controller board (2 new videos)
Bill Henning
Summary of RoboProp's features:
- Propeller running at 100Mhz with 64KB EEPROM with uSD for storage
- up to 24 servos or digital inputs with standard 3 pin pinout
- MCP3208 for eight 12-bit channels of ADC, 0-5V inputs
- L298 dual H-bridge for PWM based motor control
- and much more; please see the announcement
For a complete list of features, please see the announcement in the Robotics forum
http://forums.parallax.com/showthread.php?131348-Introducing-RoboProp-an-advanced-Propeller-based-controller-%28upgrade-for-BOE-BOT
Or you can ask for more details :-)
UPDATES:
- RoboProp is now available for sale!
- I've started adding videos to my YouTube channel - see http://youtube.com/mikronauts
Pricing:
Kits:
$99.00USD+s/h - RoboProp Full Kit - DC motor edition (includes L298 H-Bridge and related parts)
$89.00USD+s/h - RoboProp Full Kit - Continuous rotation servo edition (does NOT include L298 H-Bridge and related parts)
Assembled & Tested:
$149.00USD+s/h - RoboProp - DC motor edition (includes L298 H-Bridge and related parts)
$139.00USD+s/h - RoboProp - Continuous rotation servo edition (does NOT include L298 H-Bridge and related parts)
Please email me at "mikronauts at gmail dot com" with your address for a quote including shipping and handling.
* distributors to be announced at a later date
p.s.
Sapieha did his usual PCB layout magic - I think RoboProp looks great!
p.p.s.
All the features you see work!
UPDATES:
Pricing:
Kits:
Assembled & Tested:
p.s.
p.p.s.
Where did you get those wheels from?
What type of motor are you using? Are they faster than the Continuous Rotation Servos?
I got those Futaba servo mount wheels from Solarbotics, and I put them on the Parallax continous rotation servos that come with the BOE-BOT kit.
The wheels are a hair larger than the black Parallax wheels, so my RoboPropBOT is a hair faster than before the upgrade :-)
Now I need to make some cool demos for UPEW...
I know it will run at 96MHz as it is running fine at 100MHz :-)
I will search for spiritplumber... and while I don't have an Android phone YET, I just might pick one up just for this purpose.
I do have a couple of 7" Android tablets with WiFi... hmm... I have 6MHz crystals too... hmm....
Pins 0&1 are readily available on the EXP1 header, using them for USB only makes them unavailable for use to control servos or read digital inputs..
Thanks for the kind words!
I posted a description of the RoboProp demo with some information about the RoboProp firmware preview (and robots I took to UPEW) in post #19 in the following thread:
For the chassis in the photos above, I used a standard BOE-BOT chassis - you can start with
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/304/Default.aspx?txtSearch=boe-bot+parts+kit
or any of the other kits that include the chassis.
I added:
- RoboProp board, without populating the L298 dual H-Bridge section
- four Solarbotics Futaba/Parallax servo wheels, because my wheel encoder boards are designed for those wheels.
- two SirMorph IR sensor boards configured as 5ma low resolution wheel encoders
- one SirMorph IR sensor board configured as a rear virtual bumper
- three SirMorph IR sensor boards used as a line following sensor
- small prototype board to hold a HMC6352 I2C compass and a 38KHz IR remote sensor
By the time I showed it at UPEW last weekend, I also added a small servo for a "LIDAR" panning Sharp IR distance sensor (20cm-150cm)
I should have a production run of SirMorph sensor kits in about three weeks, I have used up all the prototype PCB's I have.
Could you narrow down for me what you are looking for?
- RoboProp "Essentials" (bare pcb, uSD socket, 6.25Mhz crystal)
- RoboProp Upgrade Kit (no parts for L298 dual H-Bridge section, otherwise all the parts that are normally on RoboProp)
- RoboProp Full Kit (all the parts including L298 section that are normally on RoboProp)
- RoboProp assembled and tested, without L298 section
- RoboProp assembled and tested, including L298 section
- or basically a fully assembled and tested RoboPropBot like above?
I will be posting more photos tomorrow.
Bill
Actually I am working on the BOM and pricing right now... I have DigiKey in one window, a spreadsheet (with parts list) in the other... trying to figure it out
For more prototyping area RoboProp (using stacking headers) can mount right on top of any of the approx. 4"x3" prototyping boards in the "Mikronauts Modular System" too!
Since you don't need the L298 populated, that means that P0-P7 and P8-P11 would be available to the prototyping board (P12-P15 as well, but the uSD card uses those pins)
I am busy doing the BOM, but in a day or two I will unpack my RoboPropBOT (RoboProp + BoeBot chassis + much more) and take some pics, maybe make some YouTube videos of it...
Thanks again for your interest. I have now finished the BOM, which allowed me to figure out the pricing:
Kits:
Assembled & Tested:
Introductory offer: 10% off the MSRP (but not the s/h) on the first ten RoboProp's (kit or assembled) sold
Email me your address for a shipping and handling quote (my email address is in my signature below)
I removed the old shots, and uploaded nine new shots to the first post
- One top view of an assembled and tested RoboProp (full kit, with L298 parts)
- Eight views of my highly upgraded BoeBOT - now RoboPropBOT named "Pollo"
"Marco" - Rover5 based, with LIDAR head, remotely controlled by my wife :-)
http://youtu.be/1lzAL_2xpIo
"LIDAR demo 1" - the RoboPropBOT (upgraded BOE) on my workbench, being turned around showing off compass and LIDAR display)
http://youtu.be/pHtKChSSW9I
I will be adding more videos this week.
