NPN as PNP
Hello!
Does anyone know if I can use a NPN transistor as if it were a PNP?
I have searched my electronics components throughly, and found to my surprise that I own not a single PNP Transistor! (At least, not that I can find....)
I understand that an NPN can invert a Positive signal, and a PNP can invert a negative signal, but can you change up where you connect the Base, Collector and Emitter to inverse th normal function of either one?
(I would much prefer to use an NPN that I have, than to drive to Radioshack and pick up a Pack of 15 2N3096 PNP Transistors for $3.00.
I am trying to build this circuit:
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
Just buy some PNPs. I keep several on hand, of various types.
What Leon & PhiPi hath decreed, I will not put asunder. They are positively negative about using NPNs as PNPs.
Virtually every sci-fi show taught electronics, computers, and science in general. Unfortunately almost always 100% wrong!
