MLX90614 Sensor Displaying in Fahrenheit — Parallax Forums
jtm1202jtm1202 Posts: 2
edited 2011-05-30 20:56 in Accessories
No trouble communicating with the sensor and getting data in Kelvin and Celsius but I would like to display the temperature in Fahrenheit as well. I am close to the goal but there is something small I have overlooked and cannot put my finger on it. When I run the program I have modified I get a reading for Fahrenheit but it is not correct. Example: When celsius reads 20, fahrenheit reads 37.
What else do I need to modify?
Find file attached
Thanks!
    edited 2011-05-27 09:52
    I'm not very familiar with the BS2, but it jumped out at me that 20 C is very close to 68 F. And 68-37= 31, which is very close to 32. Any chance you're subtracting a 32 somewhere in your conversion code where you shouldn't be?
  • jtm1202jtm1202 Posts: 2
    edited 2011-05-27 10:00
    Nice catch! I checked on that and I'm not subtracting 32 anywhere, just adding. Here is what i have
    Init:
    LOW Reset
    INPUT Reset
    DEBUG CLS, ' setup report screen
    "MLX90614 Infra Red Thermometer", CR,
    "=============================", CR,CR,
    "Kelvin......... ", CR,
    "Celsius........ ", CR,
    "Fahrenheit..... ", CR,
    "PEC test....... ", CR
    [ Program Code ]
    getTemperature:
    SEROUT Sensor,baud,[0,"!TEMR",xslave,$07]
    SERIN Sensor,baud,1000,PECfail,[tempL,tempH,pec]
    checkPEC:
    z=0
    y = xslave<<1+0
    GOSUB calculateCRC
    y = $07
    GOSUB calculateCRC
    y = xslave<<1+1
    GOSUB calculateCRC
    y = tempL
    GOSUB calculateCRC
    y = tempH
    GOSUB calculateCRC
    IF z<>pec THEN PECfail
    GOTO convertTemperatures
    calculateCRC:
    w=z^y
    READ w,z
    RETURN
    convertTemperatures:
    Kelvin = (temperature/100)*2
    KelvinDec = temperature*2
    IF (temperature < 13650) THEN overWordsize
    Celsius = (temperature/50)-273
    CelsiusDec = (temperature//50*2)
    Fahrenheit = ((((temperature/50)-273) * 18) + 32) / 10
    FahrenheitDec = (((temperature//50*2) * 18) + 32) / 10
    GOTO displayTemperatures
    overWordsize:
    Celsius = (273-(temperature/50) )
    DEBUG CRSRXY, 23, 4,"-",DEC Celsius,".",DEC2 CelsiusDec, CLREOL
    displayTemperatures:
    DEBUG CRSRXY, 23, 3,DEC Kelvin,".",DEC1 KelvinDec,CLREOL
    DEBUG CRSRXY, 23, 4,DEC Celsius,".",DEC2 CelsiusDec, CLREOL
    DEBUG CRSRXY, 23, 5,DEC Fahrenheit,".",DEC3 FahrenheitDec, CLREOL
    DEBUG CRSRXY, 23, 6,"Pass",CLREOL
    PAUSE 1000
    GOTO getTemperature
    PECfail:
    DEBUG CRSRXY, 23, 3,CLREOL,CR
    DEBUG CRSRXY, 23, 4,CLREOL,CR
    DEBUG CRSRXY, 23, 5, CLREOL,CR
    DEBUG CRSRXY, 23, 6,"Fail",CLREOL,CR
    PAUSE 500
    GOTO getTemperature
    Your Fahrenheit formula needs to add 320, not just 32.
    [SIZE=1]Fahrenheit = ((((temperature/50)-273) * 18) + 32[/SIZE][SIZE=1][COLOR=red]0[/COLOR][/SIZE][SIZE=1]) / 10[/SIZE]
    I think the other formulas and debugs are a little off, too. For example, it appears that the raw temperature value is returned in units of 0.02 Kelvin. Here is how I would write the conversions and the debugs...
    [SIZE=1]Kelvin = temperature * 2   ' in units of 0.01 K, resolution 0.02 K
    DEBUG CR, "Kevin=", DEC Kelvin / 100, ".", DEC2 Kelvin
    degC = Kelvin - 27315   ' units of 0.01 degC, resolution 0.02, can be negative[/SIZE] [SIZE=1]
    DEBUG CR, "degC=", REP "-" \ degC.bit15, DEC ABS degC / 100, ".", DEC2 ABS degC
    degF = Kelvin * 9/5 - 45967   ' units of 0.01 degF, can be negative[/SIZE] [SIZE=1]
    DEBUG CR, "degF=", REP "-" \ degF.bit15, DEC ABS degF / 100, ".", DEC2 ABS degF[/SIZE]
    note that the REP operator is used to handle the negative sign if needed, depending on the sign bit, bit15 of the number.
