SN754410 Circuit
Britannicus
As Always - after help !
I'm trying to set up a SN754410 IC to function as a motor driver - 2 motors forward and reverse. Reading the data sheets and the "how to" on http://www.hobbyengineering.com/appHBridge1A.html
It makes no mention "kickback diodes" - I think I've understood the wiring OK - can I just check the following jpg will not fry my BS2 STAMP ?? I've laid it out, just as I intend to wire it on strip board.
Initially I'm piggy-backing this off my BOE, so the PIN outs are "off board" but once I get this to work, will probably look to produce a board which has the STAMP in situ.
If I were to install kickback diodes, I don' t see how I could as to reverse the direction of current in my motor supply wires (green in the diagram) and therefore I couldn't reverse the direction of the motor.
Should I include some resistors between Pins and the IC or are these unnecessary ?
A further question - I read that I can use PWM to alter motor speed, is this just a question of polling the EN PIN with different Pulsout commands ?
I'd value your thoughts
A
A
Perhaps PWM commands?
It's "looking for" true PWM (fixed rate, variable duty) and not the Stamp's sort, but you could give it a shot.
The Stamp probably isn't the ideal microcontroller for this IC.
A Propeller could easily be made to generate the desired PWM required, and do a lot of other stuff, too.
All forgotten long ago - I'm a big history buff, so I know we only fielded the "B team" on the day anyway... now if this was a French site - now that's different !
I have to give a big chear for a great colonial today - it's exactly 100 years since Rutherford (NZ) discovered the structure of the atom - Way to Go Earnie!
As an update I built the circuit and stuck it on the BOE board and fired it up with baited breath....., Absolutely nothing... 'til I realised I'd copied the pin outs the wrong way round Doh! - A quick re-jig and it works a dream. I'm getting variable speeds by using Pulsout on the EN pins instead of a straight High/ low and I'm looking forward to sticking it in a 'bot.
Don' t know why I ever bothered with continuous rotation servos !
http://www.bbc.co.uk/news/uk-politics-13533306
Is it that your motor is good enough at lower duty and you won't require near full on or something?
With a servo it's a matter of issuing a 1-2 msec PULSOUT and then you're left with 18msec or so for other stuff before the next PULSOUT is due.
(BTW, it's Sir Ernie, cheeky. Baron Rutherford!)
