Program Stalls Problem?
Hey Everybody - I am working on an application that interfaces the Prop Proto board with an Easydriver stepper board - I had posted before about power requirements for powering the Proto board but this problem is with my actual spin program so I figured it deserved a new post?
I'm new to all this and trying to get things going and having some good success - except for one problem
I wanted a way to stop the stepper motor so what I did was say if the value I am gettin gfrom the RCMeasure is less than 350 (which is a bit more than what I get when the pot is all the way down) so when I turn the knob all the way down it stops - simple enough and it works
but sometimes it does not start back up - sometimes it does - it's weird...
It's probably something with my program so I wanted to post it here for advice
VAR
long time
long Stack[20]
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
MS1Pin = 23
MS2Pin = 19
SleepPin = 24
ResetPin = 21
PFD = 22
EnablePin = 20
DirectionPin = 17
DirectionSwitch = 7
StepPin = 18
Forward = 0
Reverse = 1
PUB Main
Cognew(StepMotor,@stack[0])
Cognew(RCMeasure,@stack[10])
PUB StepMotor
dira[StepPin] := 1
dira[DirectionPin] := 1
dira[MS1Pin] := 1
dira[MS2Pin] := 1
dira[SleepPin] := 1
outa[MS1Pin] := 0
outa[MS2Pin] := 1
repeat
if time > 350
outa[SleepPin] := 1
outa[DirectionPin] := ina[DirectionSwitch]
outa[StepPin] := 1
waitcnt(clkfreq/time + cnt)
outa[StepPin] := 0
else
outa[SleepPin] := 0
PUB RCMeasure
ctra[30..26] := %01000 ' Set mode to "POS detector"
ctra[5..0] := 16 ' Set APIN to 16 (P16)
frqa := 1 ' Increment phsa by 1 for each clock tick
repeat
dira[16] := outa[16] := 1 ' Set pin to output-high
waitcnt(clkfreq/100_000 + cnt) ' Wait for circuit to charge
phsa~ ' Clear the phsa register
dira[16]~ ' Pin to input stops charging circuit
repeat 22
waitcnt(clkfreq/60 + cnt)
time := (phsa - 624) #> 0
waitcnt(clkfreq/2 + cnt)
Another issue I can see is that both methods run concurrently without any obvious synchronisation. Which means that time may pass the > 350 test but is then reset to 0 (limit minimum) before the waitcnt. This means - SPIN enforcing n/0 == 0 - that you end up with what is basically a waitcnt(cnt), i.e. a stall. To test this scenario just lock the time value like this:
repeat if [COLOR="red"](temp := time) > 350[/COLOR] outa[SleepPin] := 1 outa[DirectionPin] := ina[DirectionSwitch] outa[StepPin] := 1 waitcnt(clkfreq/[COLOR="red"]temp[/COLOR] + cnt) outa[StepPin] := 0 waitcnt(clkfreq/[COLOR="red"]temp[/COLOR] + cnt) else outa[SleepPin] := 0A to avoid a stall due to wrap-around
