Getting Basic Stamp ID via VB2010
I was working on a project that includes all COMM Ports but am having a hard-time getting the the proper ID or Device Type to show. What I'm looking for is a way to show which port has the BS2 much like the compiler found when programming the Stamp.
The code that I've written so far was all done in VB 2010. Any guidance or suggestions would be greatly appreciated.
Here is the code so far. It's not much but I've tried several different methods to get additional information from the stamp with little success.
' Get a list of serial port names.
Dim ports As String() = SerialPort.GetPortNames()
' Show a label with Action information on it
lblComFound.Text = "The following serial ports were found:"
' Put each port name Into a comboBox control.
Dim port As String
For Each port In ports
cmbo1.Items.Add(port).ToString()
Next port
' Select the first item in the combo control
cmbo1.SelectedIndex = 0
It would be great to get not only the device type but version, loopback and echo at the same time.
Dim port As String
Next port
http://www.parallax.com/tabid/441/Default.aspx
The following is a working snippet I used at one time for the standard BS2
Private Sub reset() _port.ReadExisting() _port.DtrEnable = True Thread.Sleep(8) _port.DtrEnable = False _port.BreakState = True Thread.Sleep(52) _port.BreakState = False Thread.Sleep(10) _port.ReadExisting() End Sub Public Sub ID_BS2() _port.Write("B") TextBox1.Text = TextBox1.Text & Chr(_port.ReadByte()) TextBox1.Text = TextBox1.Text & _port.ReadByte() & " " _port.Write("S") TextBox1.Text = TextBox1.Text & Chr(_port.ReadByte()) & " " TextBox1.Text = TextBox1.Text & _port.ReadByte() & " " _port.Write(2) TextBox1.Text = TextBox1.Text & Chr(_port.ReadByte()) & " " TextBox1.Text = TextBox1.Text & _port.ReadByte() & " " _port.Write(Chr(0)) TextBox1.Text = TextBox1.Text & _port.ReadByte() & " " TextBox1.Text = TextBox1.Text & _port.ReadByte() & " " End SubJeff T.
