What would you use for a resistor?
I ran out of resistors today. Got me thinking.
What common item or not-so-common object to use as a substitute resistor?
(just for fun)
(just for fun)
Does coal really work? I know that not all forms of carbon will conduct electricity.
I suppose you could try distilled water and add tiny amounts of salt to it.
Or clip one electrode to your tongue and stick the other up your.... armpit.
Just mash it between two circuit boards, and voila, a genuine variable resistor... I bet that you allready knew about this stuff, didn't you?
Oh well, nothing to see in this post, please move along to the next post in this thread.
Thank you
-Tommy
P.S. I still have a lump of coal from christmas, Just be careful, that stuff is Flammable when you make a powder from it.
There's always my tonque if I need a lower resistance.
Oh, I got one of those late last year!!!
Did you know that you can lead a horse to water, but a pencil must be lead?
Various wattages and sizes of incandescent light bulbs. If inductance doesn't matter too much.
Some of the LEDs that Radio Shack carries have resistors in them. You could use a potentiometer.
What resistance does a capacitor have?
I would think that different guage wire might have some kind of resistance on the wattage. Different types of metal may have different resistance. You would have to use a multi-meter on different items to find out.
Maybe you could double up on the items you already are using and that would drop the current.
http://www.reuk.co.uk/Make-a-Shunt-Resistor.htm
In the old house fuse boxes, some very electrically naive people would substitute a penny or coin for an actual fuse. There was an education awareness campaign to warn people against doing that, so as not to burn down their house!
I remember in first grade, about 29 years ago, the power company came to my school and display what would happen if you did that with a penny.
and bout the dissimilar metals, I think you all may know already, but I will make a post on how to make a home made battery using pennies, nickles or dimes, a paper towel, and viniger... for those that would like to give it a try. Thanks to Forrest Mimms III's notebooks, I learned this when I was 12.
Cool, sounds interesting. Looking forward to seeing it
Things have changed because the level of copper isn't the same anymore.
http://www.wonderhowto.com/how-to-cook-hot-dog-with-leds-154557/
hahahaaa, lmao, that's hilarious. How did you even find that? did you search for LED's or "Hot Dogs"?
The black antistatic Styrofoam that Parallax uses to put their static sensitive chips in can be used as a variable resistor/pressure sensor.
Take 2 small pieces of copper clad board, about the same size as the foam., and solder a wire to each. Make sure the pieces are clean of their protective coating and residue from your finger oils. Then place the foam in betwwen the two copper clad pieces with the copper facing the foam. Apply a multimeter to the wires to measure the resistance.
Now gently squeeze the two pieces, viola, a variable resistor/pressure sensor.
