The Wonderous Unibit!
For those not endowed with fancy CNCed vertical millers with stand-em-up drill pressem thingies, the Unibit comes to the rescue!
http://forums.parallax.com/entry.php?238-Of-Things-Panels-and-Holes...
I didn't know of such a tool... I like this new forum..
Massimo
http://www.gjhall.co.uk/category/5
Robert
Robert
Great suggestion!
Not having access to a drill press, I can only imagine the level of control would be much, much better over a hand held.
Yes - limited depth for sure.
Never thought about using one on plastic - good feedback! Does the type of plastic matter?
Gratified this post initiated some good discussion.
I see the Multicut is pretty much a direct replacement for the Unibit:
http://www.gjhall.co.uk/product/6/27
I've used these before, believe it or not Radio Shack used to carry these. I imagine they probalble stopped carrying them when they got rid of allot of their electronics components. They used to be called de-burring bits. I don't know what they call them now.
My main use of de-burring bits was to clean up the mess-of-a-hole made by a regular twist bit. :cool:
I've heard these unibits called stepper drill bits. Deburring bits are not necessarily stepped.
I've heard them called a few different names too. also, hole taperers, They work well if you want inset screws that are flush with the surface by not drilling the full depth of step. I never actualy used it to drill any holes, just to deburr and taper them. You cna find the bits at different prices depending on what you call them. Like with Computer Rack Cabinets, which are expensive, but if you call them "Equipment Racks" at a music site you find the same thing for much cheaper, for example http://backstage.musiciansfriend.com/search/search.jsp?question=Rack
It's realy a multi putpose bit, I wish I could find them a bit smaller, no pun intended...
