How good (or bad) are these $50 LED projectors ("Eyeclops")
Tubular
These LED based projectors keep getting cheaper. Anyone got experience with them?
How bad are they? I know they're not good for projecting big images, but what size would be reasonable to achieve in a normal lighting office light?
You can get a "fair" 30 inch screen from it. It's a toy, but a decent toy.
Jeff
it has plenty of rsoultion but I really neds more power . I was going to hack it with a HUGE LED but I found out it used 3 LEDs as a trio not one white one as its LCoS RGB .
Peter
This is the unit I have: http://www.radioshack.com/product/index.jsp?productId=3825558
I prefer the Microvision ShowWX+ projector. I actually tested a dozen different types this past year and found it to be by far the best. They have a cheaper version called the ShowWX for $199. The ShowWX+ is $349... both are great units, however.
As for the brightest, I found that the Mitsubishi (PK) series of "mini-projectors," which are about twice the size of the Radio Shack unit are much better. They have a light output that is several times that of the other units, but they are larger. Still, they're only about 5" x 4" x 2".
Bill
I fairly like OBC's idea to mount one on a Stingray (or a mobile plywood robot), especially if you rig up an autofocus. Use a PING to get perpendicular to a wall and measure the distance, and a servo adjusts the focus to the distance.
Poor man's version: no servo. Preset the projector focus to N inches and use the PING to drive the robot exactly that far from the wall.
"Help me, Obi-Wan Kenobi. You're my only hope."
Paul
I also have a LightBlast it's better but still not a "real" projector.
I think both are worth the price though. Fun toys.
Bean
I also plan to use mine with some sort of robot. I haven't worked out the details yet.
I agree with Bean's assessment.
@Tubular, If you'd like I'll dig mine out and try to get some better quantifiable numbers. I'm not sure if photographs of the image would turn out but I'm willing to try, if you'd like.
Duane
I have this one Here you may be right but I looked more fancy insde then the micro one one .
peter
http://www.youtube.com/watch?v=WJAbV_vt1bY&feature=channel_video_title
Yeah, I thought I had come up with an original idea for my our robot, then I discovered later there are a bunch of R2D2 clones on youtube doing the exact same thing.
OBC
