Mammoth POV: an almost 5 metre, giant POV/squencer for Christmas displays etc
Tubular
This will be my entry for the Propeller Platform contest
Imagine a 5 metre long, 160 RGB led addressable rope light, being rotated the same way kids rotate long skipping ropes at primary school (one kid at each end with lots of kids jumping in the middle)
I am writing an editor based on Kye's 160*120 6 bit VGA driver to edit the sequence shown by the RGB LEDs as it sweeps around the arc. One pixel per RGB led, one row per sequence step.
Ultimately I'd like to have it read a bitmap off SD card and automatically display that bitmap, which involves syncing the rotation angle phase and speed etc.
What I really want from the forumistas at this stage is ideas for content you'd like to be displayed on this. If nothing else it should do a great job of displaying forum avatars!
Imagine if it was hung vertically and turned by a small electric motor, the a great POV display you would get
This is as far as I got tonight -
* Made a cheap "bearing" using the belled end a 20mm electrical conduit and a bit of 4x2 with a 22mm hole.
* Bought a short length of 20mm ID tube to test passing the RGB strip through. Hose clamp to connect it together. All good!
* Applied 5V power and generated a test pattern just by touching the data pins. Probably not recommended due to static, but I was running out of time. Does this qualify as "digital" data?
* Found a good test location being a 4.8m wide roller door opening (with the roller door rolled out of way)
Couple of photos below of the "electronics end" where the propeller platform will mount - there will also be a similar arrangement at the "mechanical drive" end - whether its a manual crankshaft, electrical motor or wind turbine (!)
Looking ahead... I need to look at Matt Gilliland's new power pack to see if it could deliver 5V at about 3 amps, get a 5m length of protective tube, write some test code for some simple scrolling graphics, which should come out as a barber shop style spiral when it all rotates
During testing last night i was surprised at the lack of friction between the led strip and the outer protective sheath - so turning the sheath wasn't causing the inner strip to turn. My first reaction was that I would need to fill the tube with something viscous and clear... eg Honey! It was late, ok?
Actually first I'll just try clamping the ends and see if the middle bit stays facing outwards. I could also try small clear weights that the G forces would keep outermost (thus keeping the strip innermost but facing outwards, in theory)
For powering the leds I would suggest using either slip rings or a permanent magnet motor on the stationary section rather than placing any mass on the rotating section. The pm motor could act as both the bearing and alternator to provide power to the circuitry.
There are a couple of stages to this - initially I just want to get a feel for what the minimum speed required is - and I will be turning things by hand, a crankshaft or maybe a pull string wrapped many times around one end. I'll also be using 3 AA alkaline batteries to power the leds for whatever time they run for.
I've also been thinking of running a steel rope or two through the sheath - partly to support voltage droop but this could also be a safety feature for the higher speeds later.
