Xbee solution help
The solution that I have now is a Class-1 Bluetooth USB dongle with a duck antenna, and a Class-1 Bluetooth sip module with a duck antenna. What do I need to replicate this using Xbee? I have not seen anything that is really convenient to use for the PC end, although there are some sip modules available for a link to a Propeller board. The bluetooth stuff is getting to be very expensive, the Class-1 stuff, and the Class-1 USB dongles are starting to disappear. I guess I need to start looking into a new solution, any suggestions?
Ray
Ray
What kind of data are you moving around?
If you search YouTube under stamptrol1, I've posted a demo of my XBee experiments.
Cheers,
Ray
Each end of your communication link will have an XBee plugged into an interface board. Apply power, send data in the serial side and it comes out at the other XBee/interface board.
The ones I use are Sparkfun and I got them from Solarbotics who also sells the XBee modules.
Cheers,
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/xbee/List/0/SortField/4/ProductID/643/Default.aspx
You get a serial to USB interface, and you can read data with any terminal. The X-CTU is terminal plus a couple of utilities to simplify X-bee configuration.
Massimo
