propb ?: need help adding a cog to make four lines run at same time..totally lost..?
Hello...my code for my senior project is almost perfect, which a due date looming i need some help..
My code is for two motors to run off a r/c transmitter. The pulses are perfect..the only problem now is the two motors will not run at same time...i need helping writing code for this portion.. : "question at bottom"
CODE:
PULSIN CHa, 1, X
PULSIN CHb, 1, Y
PAUSE 18
IF X < 1400 THEN M1R
IF X > 1600 THEN M1F
IF Y > 1625 THEN M2F
IF Y < 1375 THEN M2R
PAUSE 18
GOTO START
PAUSE 18
M1F:
LOW MA
HIGH MB
PAUSE 18
GOTO START
M1R:
LOW MB
HIGH MA
PAUSE 18
GOTO START
M2F:
LOW MC
HIGH MD
PAUSE 18
GOTO START
M2R:
LOW MD
HIGH MC
PAUSE 18
GOTO START
Question :
I need to be able to run the X and Y pulsins at same time as well the IF statements (2 for x, 2 for y) at sime time...and also need to run two of the four labels at same time.. ik you need to use cogs and such to make it work, this is where im totally lost with a due date looming, any help is appreciated....... i also attached the rest of the code to make it easier to read... THANKS :frown:
Thank you,,,,
CAZ
CODE:
PULSIN CHa, 1, X
PULSIN CHb, 1, Y
PAUSE 18
PAUSE 18
GOTO START
PAUSE 18
M1F:
LOW MA
HIGH MB
PAUSE 18
GOTO START
M1R:
LOW MB
HIGH MA
PAUSE 18
GOTO START
M2F:
LOW MC
HIGH MD
PAUSE 18
GOTO START
M2R:
LOW MD
HIGH MC
PAUSE 18
GOTO START
Question :
Thank you,,,,
CAZ
Sorry about the looming due date, but this is a senior project. You're supposed to have come up with a test version early enough to figure out that it didn't work as expected. You'll have to come up with the new version yourself. It's a simple enough program and PropBasic takes care of a lot of the work for you.
Wow, deja vu, my teacher pretty much said same thing today, haha.. thankss for the start!
thanks....
CAZ
Why the PAUSE 18 between the GOTO START and the M1F:?
Why the GOTO MOTOR2CODE just before the ENDTASK?
The BIG question:
Why the COGSTART MOTOR2? That's executed every time your main loop executes. What effect would that have? What about the AUTO option?
Hmmm. "Just plop this on", eh?
Hmmm. "Deja vu", eh?
good question, i kind of just used pauses in case it got bogged down, i was using a pdf file on syntax and on propbasic to write the code for cogs and it said to use AUTO if you want it to run at start of program, it also said COGSTART task to start the cog, its all confusing to me
Thanks everyone
i read in the pdf to add COGSTART task to make it run, and my task is called MOTOR2, so what you mean is when i define my task in begining of program it runs?? so i dont need to have COGSTART??
Get used to attaching your current version of your program to your messages.
The motor2 is the code, i only need two cogs, one for the first part and another for motor2 task, i got like two hours left....
What does AUTO do?
The motor2 task is for the second motor while anything before task motor2 is the first motor that works perfect, also the m2c label is so the goto mc2 in the other labels go to the start of the task.
Thanks.... running out of time
i read that cogs share outputs and inputs...
Yes they do share the inputs and outputs, BUT each one has its own definition register (DIRA) for the input/output use of the pins (the DIRection on port A).
OK i attached my code...now what..i need help badly....
See if this works:
DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 MOTOR2 TASK MOTOR1 TASK PROGRAM Start Start: TASK MOTOR1 Ma PIN 20 OUTPUT Mb PIN 19 OUTPUT CHa PIN 0 INPUT X VAR Long LOW MA LOW MB MOTOR1C: PULSIN CHa, 1, X IF X < 1400 THEN M1R IF X > 1600 THEN M1F M1F: LOW MA HIGH MB PAUSE 18 GOTO MOTOR1C M1R: LOW MB HIGH MA PAUSE 18 GOTO MOTOR1C ENDTASK TASK MOTOR2 Mc PIN 17 OUTPUT Md PIN 16 OUTPUT CHb PIN 1 INPUT Y VAR Long LOW MC LOW MD MOTOR2C: PULSIN CHb, 1, Y IF Y > 1625 THEN M2F IF Y < 1375 THEN M2R M2F: LOW MC HIGH MD GOTO MOTOR2C M2R: LOW MD HIGH MC GOTO MOTOR2C ENDTASK
This goes back to just using 2 cogs and restores your original structure, this should work if your original got one motor to work (why have a cog do nothing):
DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 MOTOR2 TASK PROGRAM Start Start: Ma PIN 20 OUTPUT Mb PIN 19 OUTPUT CHa PIN 0 INPUT X VAR Long Start2: LOW MA LOW MB PULSIN CHa, 1, X IF X < 1400 THEN M1R IF X > 1600 THEN M1F M1F: LOW MA HIGH MB PAUSE 18 GOTO Start2 M1R: LOW MB HIGH MA PAUSE 18 GOTO Start2 TASK MOTOR2 Mc PIN 17 OUTPUT Md PIN 16 OUTPUT CHb PIN 1 INPUT Y VAR Long MOTOR2C: LOW MC LOW MD PULSIN CHb, 1, Y IF Y > 1625 THEN M2F IF Y < 1375 THEN M2R M2F: LOW MC HIGH MD GOTO MOTOR2C M2R: LOW MD HIGH MC GOTO MOTOR2C ENDTASK
Might I recommend having a Propeller board at home and the components that you are working with, so that you are not limited to the time in class?
I usually do do that but i just didnt have time today to pack upp and take it homee
When i use that code the motors do not move at all.....
