Human Powered Helicopter
Girls pedals funky copter, which apparently cleared the ground barely & briefly for a first and a world record. Plenty of ground effect assist going on here!
http://news.yahoo.com/video/science-15749654/first-person-building-a-human-helicopter-25218118
@JonnyMac: I did resist the temptation to post this in your Prop forum...
http://www.HumanPoweredHelicopters.org/
Rich H
Think a person could generate enough static electricity to achieve lift-off via repulsion?
I'm envisioning a bicycle type of system that rubs giant rotors of balloon material over acres of cat fur.
I'm sure the kitties won't mind if they know it's for science.
You might be onto something.... About 12 years ago I built a 5 foot Van de Graaff generator. The main 'globe' was about 1 foot diameter while the ground return 'globe' was about 6 inches diameter attached to a 2 foot wooden dowel that I could 'safely' hold on to. (My best estimation was about 3/4 million volts with 1-2 foot arcs ... This assuming that the breakdown of air was somewhere between 1kV and 2kV per millimeter) When the Generator was charging up, there was so much attraction force between the globes with me at the other end of the wooden dowel, that it took almost all I had to keep them at a steady fixed distance to counter act the pull. I only had a 12V motor (<-- RC Airplane motor starter) turning the belt.
Sounds like a great competition for a Parallax UPNE or whatever. A Propeller can provide the control system and I bet Phil Pilgrim won't mind donating some cats to the cause.
I do think there is potential (pun intended) in electrostatic lift. Human powered? I don't know. The idea of the "Hover boards" from back to the future have always intrigued me... too bad you would need a power supply the size of the Delorean in order to accomplish it.
Bill
There are products that charge wirelessly. I kind of remember a discussion of the like on the old board.
As far as charging something wirelessly, an anomaly such as a sharp point on a highly charged object will create a "Corona Wind" capable of lighting a fluorescent light several feet away depending on the amount of charge you have to begin with.
