Propforth4.0a available for download - Page 5 — Parallax Forums
12357
  • caskazcaskaz Posts: 957
    edited 2011-04-07 06:33
    Hi.
    I added control(PWM) for brightness&contrast to 3-wire_LCDcircuit.
    I found out strange.
    Executing WORD"set_bright" on cog5 inside WORD"lcd_init".
    c" 32 5 set_bright" 5 cogx
    6 delms
    cog W@ f0 and 50 <> if ." cog5 for brightness don't start" cr then
    It takes 6mseconds to get cog number. Not good on 5mseconds.
    Is this normal?
    edited 2011-04-07 06:57
    caskaz wrote: »
    ... control(PWM)
    Is this normal?
    Sal is starting examples on PWM for servo and stepper motor control. There may be some impact from the timing alternative used, I haven't played with it yet. Also, I don't have an LCD test rig set up.
    Sal doesn't usually read the forum, please gmail him directly.
  • MGreimMGreim Posts: 118
    edited 2011-04-08 07:33
    Hi Markus! Welcome to the thread!
    Hi, Sorry for my late reply,
    The key is Clearly Defined Requirements:
    High Level Requirements - What is the end function of the final device in high level terms
    System level Requirements - what systems are need to fulfill the high level requirements
    Implementations Requirements - What functions do you need to implement to achieve the system described
    This applies to any project, but seems more obvious when using forth.
    ALSO - defining requirements is in itself an iterative process, as you define the next level, you get more insight into the previous level, and should go back and make adjustments. Generally, one does not want to start coding until all requirements are defined to the extent that you know what you have to code. This is "the easy way". Of course few do it this way, which is ok, it just takes longer to do it the hard way.
    That being said you have a good start on your requirements.
    1. Exactly what sensors/inputs do you have in mind right now specifically? Do no include "possibly.." and "maybe someday..." items, you will have enough work with today's specifics, and you can add new stuff later.
    More in details:
    - Values from a thermocouple module via I2C
    - Values from displacement sensors addressable over a RS485 network
    - Values from ADCs (all SPI bus)
    - Values from a balance (RS232)
    - Switching some relays
    a lot of stuff, but all things are quite slow (cycle time > 1s)
    2. "Intelligent I/O processor" does not sound specific, do you mean the prop is to be I/O interface and pre-processor to the ARM? If so, this should not be a problem.
    simple communication between the OMAP and the PropForth via RS232 is already running.....
    3. Propforth can easily be extended to have drivers for reading and controlling each sensor, we just need the specific parts you are targeting.
    ok...
    4. There are many choices for serial interface. If there are less than 28 or so, it is easy to have one line for each part. If there are more than that, the parts that are accessed less often can be place on a SPI bus and accesses with a shift register. The method used on the C3 board may be useful. Again, the specific parts will dictate which need a dedicated I/O line, which can be multiplexed, and what baud rate for a given throughput is needed.
    Not more then 4 or 5 (maximum)
    5. Usually you can leave the regular forth interface (Rx/TX on line 30&31) as the serial interface, and use the other pins for inter-device communication. Its easier and much more convenient, and its nice to leave something just in case you get to load up every last pin later on.
    ok
    6. As of 4.x, Sal runs his DEVELOPMENT for days at a time. The 3.x stuff was less stable in development, needed to reboot once a day, but the final apps ran indefinitely. Final apps on 4.x are (so far) completely stable (Sal has not found any evidence of instability yet).
    stability is extremely important.
    7. We expect Next week or so to have a public release of v4.5. This should be fast enough for any application you have in mind; if it isn't, the bottlenecks can be optimized in assembler.
    I think speed is not the main bottleneck, i think.
    8. If you have specifics on the I2C and SPI we can look are implementing the drivers. I haven't played with I2C and SPI myself, but Caskaz and Sal have SD support nearly complete.
    So the first step in getting stated is to state very specifically what sensor you want to monitor and define the data you wish to collect. Everything else is built on that.
    ** i think for me to implement a driver in the right way is the biggest problem. A good I2C pasm driver is already in OBEX. I have used it already in SPIN. So what i like to know how to interface such a peace of software to FORTH.
    ** SPI can be done directly in FORTH , i think.
    ** whats the best way for an add. serial interface beneath the 30-31 user interface?
    Also, if you are working on an ARM and are interested in FORTH, please check out Frank Sargents Pygmy Forth. http://pygmy.utoh.org/
    ** thats a good hint. I am thinking about talking ARMFORTH to PROPFORTH an the low level.
    If you have any requirements/specifications that you can't discuss on the thread, PM me and I will try to help properly define them. This step is critical for success. You should be able to finish defining requirements by the time V4.5 is released.
    Sorry my citation went totally wrong, i guess.
    Best Regards
    Markus
    Maybe i will send another PM
    edited 2011-04-09 20:41
    I try to make assembler code to output pulses.
    But no pulse.
    What is wrong?
    fl
    : variable lockdict create $C_a_dovarl w, 0 l, forthentry freedict ;
    0 wconstant _clk
    153 asmlabel a_pulse_out
    14F wconstant v_clk
    lockdict variable def_014F 015A l, 014F l,
    0 l, A0FE1B00 l, E4FE1B51 l, 5C7C0000 l, 68BFE94F l, 5CFEA552 l, 64BFE94F l, 5CFEA552 l, E4FE1153 l, 5CFDF0F1 l,
    5C7C0075 l,
    freedict
    1 _clk lshift constant _clkm
    : _clk_out _clk pinout ;
    \ : _clk_out_l _clkm _maskoutlo ;
    \ : _clk_out_h _clkm _maskouthi ;
    : test
    _clkm v_clk COG!
    v_clk COG@ .
    _clk_out
     begin
    1000 a_pulse_out  drop
     0 until
    fl
    :asm
    v_clk
    0
    __delay
    mov _treg5 , # 100
    __C
    djnz _treg5 , # __C
    __delayret
    ret
    a_pulse_out
    __1
    or outa , v_clk
    jmpret __delayret , # __delay
    andn	outa , v_clk
    djnz _sttos , # __1
    spop
    jnext
    ;asm
    edited 2011-04-10 04:38
    caskaz wrote: »
    I try to make assembler code to output pulses. But no pulse.
    I don't see any code setting dira. Where is that done?
    edited 2011-04-10 04:58
    Hi kuroneko-san.
    There is "_clk_out" inside WORD"test.
    edited 2011-04-10 05:00
    Schottky diode ( wikipedia) not shotkey
    Regards
    Markus
    edited 2011-04-10 05:21
    Sorry.
    After uploaded ipg, I'm aware spell mistake too.
    edited 2011-04-12 22:16
    0 l, A0FE1B00 l, E4FE1B51 l, 5C7C0000 l, 68BFE94F l, [COLOR="red"]5CFEA552[/COLOR] l, 64BFE94F l, [COLOR="red"]5CFEA552[/COLOR] l, E4FE1153 l, 5CFDF0F1 l,
    5C7C0075 l,
    fl
    :asm
    v_clk
    0
    __delay
    mov _treg5 , # 100
    __C
    djnz _treg5 , # __C
    __delayret
    ret
    a_pulse_out
    __1
    or outa , v_clk
    [COLOR="red"]jmpret __delayret , # __delay[/COLOR]
    andn	outa , v_clk
    djnz _sttos , # __1
    spop
    jnext
    ;asm
    The encoding for those two jmprets is wrong. The hex value represents a jmpret __delayret, #__delayret, i.e. src and dst fields are the same ($2A552 = %101010010_101010010). As the ret starts out as a jmp #0 this is likely to go wrong. I assume there is some 3rd party assembly involved so that's the first place I'd look for the address mismatch. FWIW, $5CFEA550 would be the correct value.
    edited 2011-04-16 00:55
    Hi kuroneko-san.
    Sal gave me advice.
    Mistake is no "def_014F lasm" and incorrect label-name"__delay __delayret".
    Correct code is below;
    fl
    : aallot coghere W+! coghere W@ par >= if 8005 ERR then ;
    : cog, coghere W@ COG! 1 aallot ;
    : lasm 4+ dup L@ swap 4+ swap over L@ dup coghere W! do 4+ dup L@ cog, loop drop ;
    0 wconstant _clk
    14F wconstant v_clk
    0 l, A0FE1B00 l, E4FE1B51 l, 5C7C0000 l, 68BFE94F l, 5CFEA550 l, 64BFE94F l, 5CFEA550 l, E4FE1153 l, 5CFDF0F1 l,
    5C7C0075 l,
    freedict
    : test
    def_014F lasm
     _clkm v_clk COG!
     v_clk COG@ .
    _clk_out
     begin
         1000 a_pulse_out
     0 until
    fl
    :asm
    v_clk
    0
    __Ddelay
    mov _treg5 , # 100
    __C
    djnz _treg5 , # __C
    __Edelayret
    ret
    a_pulse_out
    __1
    or outa , v_clk
     jmpret __Edelayret , # __Ddelay
    andn	outa , v_clk
    djnz _sttos , # __1
    spop
    jnext
    ;asm
    edited 2011-04-16 07:23
    I made 2-wire LCD driver(using forth assembler).
    Loading
    1 2-wire_LCD_1.0.f
    2 extra_LCD_1.0.f (Control for brightness&Contrast)
    3 LCD_demo.f
    I check display-time(not including lcd_init) by demo2(moving Wave).
    Normal driver(E RS D4-D7:6-wire) 10.7sec(32E845F0ticks)
    3-wire LCD driver(latch clk data:3-wire) 17.9sec(5596AC70ticks)
    2-wire LCD driver(latch clk :2-wire) 8.7sec(2985D9A0ticks)
    edited 2011-04-19 01:05
    Hi.
    I modified Dynamic Drive 7SEG-LED driver by using 3-wires.
    There is dd-LEDcircuit at #113 in this thread.
    Display cannot do at 1093Hz.
    When digits(inside 3-wire_dd7SEG) is 2 (Hardware is 3-digits), third digit may display number.
    Because this is pullup to 3.3V on SRCLR.
    edited 2011-04-23 06:11
    Hi.
    I updated 2-wire_LCD.
    Searching free cog for controlling LCD's contrast & brightnes.
    edited 2011-04-30 08:17
    edited 2011-05-07 20:37
    Hi.
    I did SPI-communication between protoboard(forth_master_0.1.f) and demoboard(slave_SPI_0.1.spin).
    This is very slow since using forth-word and SPIN.
    I think assembler need.
    Connected resistor(220ohm) on pins between protoboard and demoboard.
    Loaded forth_master_0.1 on protoboard.
    Loaded slave_SPI_0.1to ram or eeprom on demoboard.
    Executed WORD"demo" on protoboard.
    edited 2011-05-08 08:23
    Did we ever get resolution to the EEPROM files system issue 25?
    Last indication was a hardware issue. Can we confirm that this is the case?
    Otherwise we will consider this issue closed until more information is available.
    edited 2011-05-08 08:30
    caskaz wrote: »
    Hi.
    Connected resistesr(220ohm) on pins between protoboard and demoboard.
    Nice work! I'll try and set this up and do some tests, but it will have to wait till after testing on Sal's new servo control code is finished.
    My comment on this is to mention the convention for "print words".
    The tradition is to designate words that print character to the display by prefixing them with a period. So the "traditional" form for your words would be to change:
    : msg c" May the FORTH be with you" ;
    : kb c" Keyboard is " ;
    : ms c" Mouse is " ;
    : msg1 c" not connected" ;
    : msg2 c" connected" ;
    : mouse1 c" 2-button mouse" ;
    : mouse2 c" 3-button mouse" ;
    : mouse3 c" 5-button mouse" ;
    : button c" button status" ;
    : mouse4 c" left center right" ;
    : mouse5 c" deltax deltay deltaz" ;
    : on c" ON " ;
    : off c" OFF" ;
    to:
    : .msg c" May the FORTH be with you" ;
    : .kb c" Keyboard is " ;
    : .ms c" Mouse is " ;
    : .msg1 c" not connected" ;
    : .msg2 c" connected" ;
    : .mouse1 c" 2-button mouse" ;
    : .mouse2 c" 3-button mouse" ;
    : .mouse3 c" 5-button mouse" ;
    : .button c" button status" ;
    : .mouse4 c" left center right" ;
    : .mouse5 c" deltax deltay deltaz" ;
    : .on c" ON " ;
    : .off c" OFF" ;
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-05-08 18:55
    Prof_Braino:
    Could you recommend any good forth tutorials? I have very little experience with forth, to the point of being almost a noob in the area of the Forth language.
    edited 2011-05-10 07:14
    Prof_Braino:
    Google Leo Brodie. PM me if you have specific questions. Once I get started, I can go on and on, its best not to babble in public.
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2011-05-10 16:26
    Is Propforth 4.0 compatible with the Demo Board? If not, which version is the most recent? Thanks.
    edited 2011-05-10 20:19
    Kevin Wood wrote: »
    All versions of propforth will run on any prop chip. There are some configurations that look for specific hardware, for example the JupiterACE configuation expects the demobpard pinout for VGA and keyboard, and the Hive configuration expects the Hive pinout for VGA and keyboard.
    The EEPROM filesystem expects a 64k EEPROM, which I belive is on all prop boards EXCEPT the demoboard, but you don't have to load it, and if you do load, you don;t have to execute those words. (Don't ask me why, but folks do this. OK ask me why, I'll tell you: they want to see if it breaks)
    I usually use the demoboard when I use VGA, and I usually DON'T use the EEPROM file system on the other boards, except in testing.
    I usually load working code into RAM and do a saveforth, which over-writes the low 32K EEPROM with the current dictionary.
    I load code under test into a freshly booted prop which has my working code saveforth'd.
    Version 4.0 is the lastest release from the author, the 4.0a version was an attempt by me to better organize, but this attempt had limited success.
    Next version targeted is version 4.5 next month which will have spineret specific functionality: Ethernet, telnet server, HTML5 server, forth execution in HTML pages, Time over internet. Also may have RAW SD support, block access, FAT comaptibility NOT implemented.
    Final development version (may be) verison 5 in august, with support for minimum permanent kernal (about 4k?), on the fly compilation from SD, and auto-forget, to allow unlimited application and data size (with a 32k max size at any given time, of course).
    edited 2011-05-10 22:12
    Okay, I downloaded PF4.0, and did the following...
    a) loaded the .spin file into eeprom
    b) loded PropForthCore.f via Tera Term
    c) ran saveforth
    Where does that leave me? I'm guessing with a minimal system? Do I need anything else to work with the demo board?
    Also, how do I view the Prop and Version info? I tried running the commands, but I must be missing something.
    Thanks.
    edited 2011-05-11 07:32
    Kevin Wood wrote: »
    c) ran saveforth
    Thanks.
    The comments in the readme are supposed to indicate that the spin file is just the minimal system.
    PropForthxxx.f addes various development extensions. ONE file is for recreatingthe minimmal kernel, the other is for development.
    If you did it correctly, when you type "words" your should get a display of all the words, thefunctions present in the dictionaqry.
    Now you can access any functionality of the prop hardware using the command line. The most commlonly used are defined as FROTH words, the less commonly used are accessed thru assembler.
    Try to follow the examples, at one time they were sufficient; PM me if you find errors and I will make correction.
    Also try the Brodie books, the PC oriented material needs modification, but the basic material should still be the same.
    edited 2011-05-12 06:25
    Any idea how to send a break (2ms) ?
    A simple idea:
    2 cogstop
    4 5 9600 2 startserialcog
    c" teststring sending " 2 cogx
    \this works fine
    \now i will try to send a break on TxD
    4 pinlo
    2 delms
    4 pinhi
    seems not to work, because the serilacog seems to stuck port 4
    The most clean way would be , to realize it in the serial driver stuff, i think. Any ideas
    Markus
    (i have cross posted this question in the German Hive forum)
    edited 2011-05-12 09:17
    Hi.
    I have idea.
    But I don't test it.
    This code might be wrong.
    : break_out
    io 2+ W@ swap cogio io 2+ W!
    cnt COG@
    begin 0 cr dup cnt COG@ swap 27100 >       / wait 2msec
         if drop 1 else 0 then
    until
    io 2+ W!
    2 break_out   \ send 2msec-break to cog2's serial
    Sorry, I had misunderstanding break-signal.
    Break-signal don't has start-bit/stop-bit. Still low.
    I think above code send 0x00.
    My idea:
    1 stop serial on cog2
    2 pin4 to low
    3 wait 2msec
    4 start serial on cog2
    edited 2011-05-13 09:01
    I have now modified the startserialcog or better said the serentyPFA routine a little bit,
    if a special sign (now ASCI 7C) is handled a 32bit high signal is clocked out.
    I would like to take another AsCI code like $00 but i dpn't understand how to
    make something like
    c" $00 " 2 cogx
    the 2nd line didn't work (its sending $ 0 0 ).
    Any idea how to make string out of any ASCII character(s) ?
    Markus
    P.S. I will post my code tomorrow
    edited 2011-05-13 11:20
    MGreim wrote: »
    ... modified the startserialcog .... serentyPFA routine
    c" $00 " 2 cogx
    The construct
    c" My text here "
    is the text handling mechanism
    The construct
    0 emit 32 emit 40 emit
    is for outputing numerical values off the stack
    Did you try:
    7 emit 0 emit 4F emit 4B emit 2 cogx
    I didn't check, but I think that
    " 7 emit 0 emit 4F emit 4B emit "
    gets put into cog 2's input buffer, andit executes just as if you typed it from the command line.
    edited 2011-05-13 11:43
    I looked at some of the docs on the google code site.
    The Polish notation is a bit quirky...be hard to get used
    to it I imagine. Is there a free Forth book for idiots somewhere?
    Two and two, multiply.... four you will have!
    images?q=tbn:ANd9GcS-Kh_n2NoJUm9fGfyp6FcNjY3yVAi2TPA0DmObupLwcQ2iXYRAWg
    2Q==
    edited 2011-05-13 12:03
    ... docs on the google code site. The Polish notation is a bit quirky...be hard to get used to it I imagine. Is there a free Forth book for idiots somewhere?
    The documentation on google docs is weak since I haven't gotten a lot of feedback. If you see anything the needs fixing let me know.
    The reverse polish notation is actually easy, it's just like the plate stacker in the diner, if you ever had to bus tables. Its no harder than infix notation, but it is different.
    Google Leo Brodie and you can find the free PDF's for "Starting Forth" and "Thinking Forth". These predate the "for dummies" series if I remember. These were the starting texts for almost everyone except Charles Moore.
  • SSteveSSteve Posts: 808
    edited 2011-05-13 12:21
    Starting Forth is the bible for Forth beginners. It is available online at http://www.forth.com/starting-forth but I haven't been able to find a PDF version. There is a PDF version of Thinking Forth at http://prdownloads.sourceforge.net/thinking-forth/thinking-forth-color.pdf?download. Thinking Forth isn't so much a Forth beginner's book as a general programming practices book using Forth for examples. It's a great book, but Starting Forth is the one to start with.
    All this talk of Forth has made me nostalgic. Back in the second half of the 80s I wrote the first commercial MIDI voice librarian program for DOS. It was all in Forth. I haven't had time to explore Propforth yet, but this has got me to install gforth on my Mac and play around with it a little.
