Prop Stick USB issue
Hello all
I have been experimenting with a Prop Stick USB for the first time. The project is running off a 12v car battery, and uses a 5v switching regulator to power the PCB and Prop Stick. RESn is floating on the device, VDD off the device is powering an external eeprom only. VIN is the 5 volts from the external regulator(on the PCB). All grounds are tied together on the PCB>Prop Stick.
If the USB cable is plugged into a computer to the Prop Stick, the device boots normally. If the usb cable is unplugged, device runs the first set if init codes ( not all ) and reboots over and over again. I will do further testing this afternoon, but it seems like it reboots at the StartSerial method which sets up the 4 port full duplex object.
I am at a loss for this issue, if anyone has a suggestion I would be glad to hear some input.
Much appreciated!
