FemtoBasic with 4GB uSD card? — Parallax Forums
zappmanzappman Posts: 418
edited 2010-07-26 17:44 in Propeller 1
Will FemtoBasic work with a 4GB uSD card?
My demo board and 4GB uSD card work with the FAT16/32 Full File System Driver by Kwabena W. Agyeman, the version that works without a clock. I can even play wave files off the card.
When I try to access the card in FemtoBasic, by typing 'files' then return, I get a message 'Can't Mount SD Card'
I think this is a FAT16/32 problem?
Thanks in advance for your help,
zappman
Visit Zappman's Blog at Savage Circuits
    edited 2010-07-25 21:32
    Make sure you have the current FemtoBasic version (3.009) from the Object Exchange. The SD card driver was updated a few weeks ago to use Rokicki's FSRW 2.6. It's supposed to work with FAT32 as well as FAT16, so it should work with a 4GB uSD card.
  • zappmanzappman Posts: 418
    edited 2010-07-25 22:11
    Yes, have i have FemtoBasic version (3.009) from the Object Exchange
    The object contains fsrwfemto.spin with the comment v2.6a 3 June 2010 Modified to make compatible with FemtoBasic.
    I am using the Parallax micro-SD Card Adapter (#32312)
    The program below works perfect so I think my wiring is OK.
    SD2.0 FATEngine Demo
    ¦ Author: Kwabena W. Agyeman
    ¦ Updated: 6/2/2010
    ¦ Designed For: P8X32A @ 80Mhz
    ¦ Version: 1.0
    edited 2010-07-25 22:22
    Do other uSD cards work with your setup and FemtoBasic?
    edited 2010-07-25 22:38
    I only have the one uSD card, so the answer is no I don't have any other uSD cards that work with my setup and FemtoBasic.
    I could buy another (smaller) card I guess.
    The card was formatted on a laptop if that makes any difference.
    edited 2010-07-25 23:09
    I had only tried FemtoBasic with 2GB FAT32 uSD cards since I don't have any 4GB cards handy and it seemed to work. It may take 2 or 3 weeks before I have time to work on this. Thanks for letting me know. I'll have to get a set of larger uSD cards to test things more thoroughly.
    edited 2010-07-25 23:22
    Thanks for your help, I will try a 2GB Fat 32 uSD card.
  • hinvhinv Posts: 1,252
    edited 2010-07-26 16:05
    I believe any uSD card over 2GBm would be SDHC. I'm not sure what the difference is in accessing them though.
  • localrogerlocalroger Posts: 3,451
    The difference between SD and SDHC is that in SD, when you request a block you specify its 32-bit starting address; this would give 4 GB but many drivers use signed math so they're limited to 2 GB. With SDHC you specify the block number. If you want to support both formats when booting the card you also need to check some registers to determine whether it's SD or SDHC; afterward the only difference is whether you shift the block number left before sending it to the card.
    You could support SDHC only just by eliminating the block number to address shift in the old driver.
