Problem using local variables in sxb2 — Parallax Forums
T'SaavikT'Saavik Posts: 60
edited 2010-05-02 14:12 in General Discussion
I was having trouble with this code
SUB LIFT
   Local_Drive VAR BYTE
   Local_Drive = __PARAM1
   Local_Counter VAR WORD
   WATCH Local_Drive
   BREAK
   if Local_Drive = 0 THEN
No matter what I passed to this subroutine (0,1,2) the IF always returned true (input was read as 0)
Changing counter from a WORD to a BYTE fixed it.
I have a feeling this may have something to do with what i set the local stack size to?
STACK             16
Am i correct in assuming that a stack of 16 is equivalent to a word, and therefor i overflowed my stack?
I am still working on this code, but if you want to view it in its current entirety it is available at: www.hellspark.com/dm/ebench/sx/dave/cdavenger.sxb
UPDATE:
It would appear that my Local_Drive variable is incrementing itself even after the above 'fix' ?!?! I'm still trying to figure it out
UPDATE2: The for loop on another local variable is causing it somehow!
Lift_Delay     CON  120  'This is at the top of the program, thought it might be handy to know it was over 255.
For Local_Counter=0 to Lift_Delay
         PULSOUT White_CD_Lift, Lift_Right
         PAUSE 20  'I had delay_ms sub but replaced to simplify
NEXT
UPDATE3:
I created a global counter variable and it fixes the problem!
Post Edited (T'Saavik) : 4/30/2010 8:14:17 PM GMT
  • BeanBean Posts: 8,129
    "STACK 16" means 16 bytes.
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
    There are two rules in life:
    · 1) Never divulge all information
    If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
