Ping))) Sensor and Servo — Parallax Forums
Joe24Joe24 Posts: 1
edited 2009-05-01 21:02 in Accessories
hello,
I'm trying to do a simple object tracking using the Ping module and a servo. I used the "roaming with Ping" example but can't seem get the code correct.
The sensor is mounted in my Boe-Bot and all I want it to do is track an object in front of it.
I·know that this is trivial but I cannot seem to get this right.
can someone point me the right way?
Joe
  • SRLMSRLM Posts: 5,045
    Can you post the code that you have? Use the attachment option. Also, a better description of what you want to do is in order. How exactly do you plan to track something?
