PIR sensors — Parallax Forums
PIR sensors
Morgan AndersonMorgan Anderson Posts: 2
edited 2009-03-06 15:58 in Accessories
I'm working on a project for school currently and we have to make two robots communicate. I'm a beginner and havn't found much detail on sensors atleast at my level. So what i was thinking is using two PIR parallax sensors. How would i go about interfacing these to my robot which uses a 28 pin parallax BS2e, and what kind of code would i use?
  • SRLMSRLM Posts: 5,045
    edited 2009-03-06 02:04
    Okay, you're talking about two different things: communication and the PIR.
    Communication is easy: there are any number of wireless modules available, including a set that Parallax sells. Other popular choices are the Xbee family of radios.
    The PIR sensor is quite easy too. It simply has two outputs: see movement or doesn't see movement (high or low). You can just hook it up to a pin and us INX where X is your pin number.
    Take a look on the product pages for the sensors that you're looking at: they all have sample code for the BS2, but you don't need to change anything at all to use with the BS2e (except for the compiler directive)
  • Morgan AndersonMorgan Anderson Posts: 2
    edited 2009-03-06 14:49
    So i want to know if pir sensors or rf would be the better way to go with inter robot communication. also if i use·either·form·how do i interface the sensor or radio to my robot. When i program the robot am i programming the parallax sx chip, and the micro and rs232? or just the parallax. my robot has two spots to hook up to the parallax chip p0-p15 one with 220ohm resistors and one without. also i have to interface a lcd screen with my robot and display how my robots are communicating.
    The PIR sensor is not used for communication, and in no effective way can it be used to do so. It is a sensor that senses changes in IR light (movement of warm people).
    Generally, you don't program peripherals like the PIR sensor or a wireless module. For the wireless, you'll probably send it commands and data via a SEROUT command, or maybe a SHIFTOUT command.
    Like I said, take a look on the product pages from parallax. Sample code is generally available.
