Shop Learn
is propeller I2C enabled? — Parallax Forums
ALIBEALIBE Posts: 299
edited 2006-03-31 20:10 in Propeller 1
is it?
I have a devantec srf08 range sensor from brainstem. Can propeller drive I2C devices
thanks
    edited 2006-03-31 20:03
    With a bit of code, sure. I'm working on an I2C object.
    Jon Williams
  • ALIBEALIBE Posts: 299
    edited 2006-03-31 20:04
    thanks -
    does the dev board have an i2c port? i did not see in the pic.
    edited 2006-03-31 20:07
    Any two pins can be used for I2C (will pull-ups, of course). On start-up, the user program is loaded from a 24LC256 EEPROM (I2C) on pins A28 and A29. In my planning, I'm going to use these pins -- being careful not to write anything to the device at address %000 as that could corrupt the program to a subsequent start-up.
    Jon Williams
    ok - that will work.
