help me — Parallax Forums
help me
lulululu Posts: 2
edited 2005-09-18 17:20 in Learn with BlocklyProp
hi everyone.
I'm having a problem with blinking LEDs by using BS2.
I want the LEDs to blink only after switch1 is pressed, released, and then switch2 is pressed.
Is this possible? How should I make such a program??
    edited 2005-09-18 13:27
    I would do somthing like this:
    Main:
    · DO
    ··· DO : LOOP UNTIL (Switch1 = Pressed)
    ··· DO : LOOP UNTIL (Switch2 = Pressed)
    ··· DO WHILE (Switch2 = Pressed)
    ······TOGGLE LED
    ····· PAUSE 100
    ·· ·LOOP
    · LOOP
    I will leave you to the details.
    Jon Williams
  • lulululu Posts: 2
    Dear Mr. Jon Williams
    Thak you so much for your reply, and it worked!!!
    I really appreciate your suggestion. Thank you!!
