Hexcrawler RC Power Needs
Few more questions, hoping to get some input...looking at power requirements for this thing..
I show..
BOE..7.2V battery..no problem..
video xmtr...14.4 V..no problem
camera...14.4V..is anyone concerned that the spec on the camera (CNL-100C) says 12V max..???..I'd be worried about no load conditions on the cam...
SSCs...7.2V, or.stick to the 9V batteries?
R/C rcvr..rechargeable battery supplied with unit..
servos..7.2V..has anyone considered a separate 7.2V battery for these...??
Open to any and all comments...
I show..
Thoughts look good, just make sure that the camera does not receive much more than 12V, as this will cause permanent damage to the unit.
Steve Halla
www.vir-inc.com
So my other two questions still are..
Has anyone had experience running the SSCs on 7.2V?...with the bottom limit on the spec sheet being 7V, that might make me a bit nervous..I might be more inclined to tie both of them to 14.4...
Has anyone seen a performance improvement with a separate 7.2V battery for the servos, or, dropping one in parallel with one of the 7.2 V batteries that make the 14.4 series chain, thereby giving a bit of a current boost to the servos...??
