share I/O pins with IR detector — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-17 20:39 in General Discussion
Hello again all. I was asking about sharing Pins with Ir detectors that
outut a 0(low) for detection. My bumper sensors use a pullup resistor and
also output a 0(low) on detection. If I use the Diodes as somebody
suggested,wont the two sensors step on each other?
how would my bumper send out a low state and the IR sending out a high state
and both feeding into the pin at the same time?
I would try it,but hate to burn up my stamp. I dont care about losing a
cheap IR detector,but hate to lose a stamp <S>
Below is what I would like to do, without the smell of smoke <S>
+ 5V
\ resistor
| | IR | Radio shlock
detector outputs a 0 for detection
Pin
| |______|
/ switch
- Gnd
Sincerely
Kerry
http://Mntnweb.Com
WWW hosting and Authoring
Admin@M...
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-17 18:31
    The diode circuit that another list member described
    for you keeps the inputs from "stepping on each other."
    It's called a "wired-OR" circuit. Either source can
    pull your input LOW. If they're both HIGH, nothing happens.
    Reg Neale
    edited 2000-03-17 19:23
    Kerry:
    If you connect two diodes as I suggested, the sensors are isolated from each
    other. You connect a diode from stamp pin to the first sensor, and another
    diode from the stamp pin to the 2nd sensor. The diodes point away from the
    stamp toward the sensors. Therefore, the sensors can sink current, but not
    source current. Then you use a pullup resistor on the stamp pin since the
    sensors can no longer pull up the stamp. A 10K resistor would be OK for
    pullup.
    Ray McArthur
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Friday, March 17, 2000 12:36 AM
    Subject: [noparse][[/noparse]basicstamps] share I/O pins with IR detector
    state
    > + 5V
    > \ resistor
    > | | IR | Radio shlock
    > Pin
    > | |______|
    > / switch
    > - Gnd
    > Sincerely
    > Kerry
    > http://Mntnweb.Com
    > Admin@M...
    > eGroups.com Home: http://www.egroups.com/group/basicstamps/
    > http://www.egroups.com - Simplifying group communications
    This is not my question. My question was locating
    examples of somene using the stamp as a fuel injector
    based on RPM and Boost pressure.
    >From: "rjmca" <rjmca@w...>
    >Reply-To: basicstamps@egroups.com
    >Subject: [noparse][[/noparse]basicstamps] Re: share I/O pins with IR detector
    >Date: Fri, 17 Mar 2000 14:23:01 -0500
    ><< text1.html >>
    ______________________________________________________
    Get Your Private, Free Email at http://www.hotmail.com
