bipolar stepper motor?
WhelzornWhelzorn Posts: 256
edited 2004-09-01 - 17:09:12 in Robotics
Well, I have this linear motion table thing (made by NEAT) that I found a year or so ago, and am wondering now what the hell to do with it. Anyway, I decided to first figure out how to use the thing, so I used a 5v transformer and figured out the pinouts, and that there is, indeed, a bipolar stepper motor inside. Anyway, this is the first bipolar stepper motor I have ever used and I am wondering how to use the basic stamp to drive this thing, without harming the basic stamp. I know that since its bipolar, I need to reverse the polarity on the coils inside to drive it, but I dont know how to do that without using 8 of my bs2's pins, and a load of transistors. So, I'm wondering if anyone has ever driven a bipolar stepper with the BS(1,2,whatever) and how they did it. I am aware that they make stepper motor drivers, but I dont know where to get these little buggers, and I would like to use only a bs2. I do have a microstepper I used to drive a unipolar, but it in enourmous, and probably won't fit into the size constraints of my project. Thanks for the help in advance!
    The Bipolar stepper motor (even number of wires in pairs) uses a device similar to an H-bridge driver to interface with the BasicStamp.
    A Uni-polar stepper (odd number of wires - all the leads are tied to a common lead) can use the UNL3803A Darlington array to drive two steppers from the BasicStamp.
    The problem is how the Bipolar is switched (from supply and ground and vise-versa) -- both units use the same pattern to step through a rotation clockwise or counter-clockwise. The Nuts and Volts articles talk about a very good H-bridge chip that will control this directly from the Stamp as well as controlling an H-bridge. I am not sure, but you may need two of these chips for all the coils.
    There are a lot of good, small chips that will drive this directly from the BasicStamp - I depends on what is available cheaply, near you. You don't have to build a lot of controls or buy an expensive controller.
    G. Herzog in Taiwan
    Post Edited (Kramer) : 9/15/2004 2:30:14 PM GMT
