Can I change the title of a thread I started ? Yes I can... — Parallax Forums
BeanBean Posts: 8,129
edited 2004-08-30 15:28 in General Discussion
Post Edited (Bean) : 8/30/2004 4:23:42 PM GMT
  • Jim EwaldJim Ewald Posts: 733
    You should be able to edit your posts. If you post is the first in the thread, you should be able to adjust the subject line as well. Click on the pencil icon. located in the upper right corner of your post, and see if you are permitted to change the subject. I'm just not sure if that is a moderator-only feature.
    Jim
    Parallax IT Dept.
