Traffic Light Code
Hello all, This is my first post and I am a novice to Parallax microcontrollers. I saw this traffic light on a youtube video and having some interest in these types of projects, I just had to try it.
The code below in it's original unedited state (except for ports) but there seems to be some problems with this or I am missing something.
I have studied the code and understand most of it. The code for the most part is running as it should. The Ping sensor is active and displays distance perhaps in mm and does change the switch dependent on distance but I am having difficulty with the reset portion of this code as it does shut off all lights once the LIGHT_ON_TIME is reached but does not seem to reset so the light are active again. I have done some experimenting with the code and changing line 53 from 0 to 1 "timeLightHasBeenOn = timeLightHasBeenOn + 1" does produce a timing output . But my main obstacle is the reset portion of this code I am sure this timer is directly related to my issue as is line 103 "timeLightHasBeenOn = 0".
Any help with this would be greatly appreciated. TY
• I believe the system is suppose to reset after a certain X time but does not
• Would like distance to read in inches and cm and the timer to read actual second.
1. 'Distance constants
2. GREEN_DISTANCE CON 11000
3. YELLOW_DISTANCE CON 7500
4. RED_DISTANCE CON 4600
5. CmConstant CON 2260
6. InConstant CON 890
7. 'Time constants
8. LIGHT_ON_TIME CON 1000
9. 'Light States
10. LIGHT_OFF CON 0
11. RED_LIGHT CON 1
12. YELLOW_LIGHT CON 2
13. GREEN_LIGHT CON 3
14. 'IO PINS
15. GREEN_IO_PORT CON 13
16. YELLOW_IO_PORT CON 14
17. RED_IO_PORT CON 15
18. PING1_IO_PORT CON 5
19. 'Variables
20. timeLightHasBeenOn VAR Word
21. distanceSensor1 VAR Word
22. lightState VAR NIB
23. distanceFiltered VAR Word
24. distance VAR Word
25. cmDistance VAR Word
26. inDistance VAR Word
27. time VAR Word
28. 'Initialize variables
29. lightState = LIGHT_OFF
30. timeLightHasBeenOn = 0
31. distanceFiltered = 0
32. 'Turn off lights
33. LOW GREEN_IO_PORT
34. LOW YELLOW_IO_PORT
35. LOW RED_IO_PORT
36. 'Loop forever
37. DO
38. 'Get the distance from sensor #1
39. PULSOUT PING1_IO_PORT, 5
40. PULSIN PING1_IO_PORT, 5, distanceSensor1
41. 'cmDistance = cmConstant ** time
42. 'inDistance = inConstant ** time
43. 'DEBUG HOME, DEC5 cmDistance, " cm"
44. 'DEBUG CR, DEC5 inDistance, " in"
45. distanceFiltered = distanceFiltered - (distanceFiltered/5-distanceSensor1)
46. distance = distanceFiltered / 5
47. DEBUG HOME, "distanceRaw = ", DEC5 distanceSensor1, "; distanceFilt = ", DEC5 distance, "; timer = ", DEC5 timeLightHasBeenOn, CR
48. 'Check for car present
49. IF (distance < GREEN_DISTANCE) THEN
50. 'If car has just arrived, then turn on the light!!!
51. IF (timeLightHasBeenOn < LIGHT_ON_TIME) THEN
52. 'Increment timer
53. timeLightHasBeenOn = timeLightHasBeenOn + 0
54. 'Determine which light: green, yellow, or red
55. SELECT distance
56. 'Green light - bumper not detected yet
57. CASE > YELLOW_DISTANCE
58. IF lightState <> GREEN_LIGHT THEN
59. lightState = GREEN_LIGHT
60. 'Turn green on
61. HIGH GREEN_IO_PORT
62. LOW YELLOW_IO_PORT
63. LOW RED_IO_PORT
64. ENDIF
65. 'Yellow light - bumper detected but not at the top height yet
66. CASE > RED_DISTANCE
67. IF lightState <> YELLOW_LIGHT THEN
68. lightState = YELLOW_LIGHT
69. 'Turn yellow on
70. LOW GREEN_IO_PORT
71. HIGH YELLOW_IO_PORT
72. LOW RED_IO_PORT
73. ENDIF
74. 'Red light - at the top height
75. CASE ELSE
76. IF lightState <> RED_LIGHT THEN
77. lightState = RED_LIGHT
78. 'Turn red on
79. LOW GREEN_IO_PORT
80. LOW YELLOW_IO_PORT
81. HIGH RED_IO_PORT
82. ENDIF
83. ENDSELECT
84. 'Car has been here for a while so turn off the light
85. ELSE
86. IF lightState <> LIGHT_OFF THEN
87. lightState = LIGHT_OFF
88. LOW GREEN_IO_PORT
89. LOW YELLOW_IO_PORT
90. LOW RED_IO_PORT
91. ENDIF
92. ENDIF
93. 'No car is present
94. ELSE
95. 'Make sure lights are turned off
96. IF lightState <> LIGHT_OFF THEN
97. lightState = LIGHT_OFF
98. LOW GREEN_IO_PORT
99. LOW YELLOW_IO_PORT
100. LOW RED_IO_PORT
101. ENDIF
102. 'Reset the timer
103. timeLightHasBeenOn = 0
104. ENDIF
105. PAUSE 100
106. LOOP
107. END
Which Parallax microcontroller are you using?
Please post your code using the Code directive "C" in the menu bar.
As Dave asked above, it looks like Basic Stamp code- so I'll move this to the Basic Stamp forum for you, as you should catch the eye of more Stamp experts that way.
I've added the code tags for you too, just to make the code easier to read.
When you post code next time, then click that C button above the posting text box, and you'll get code tags appear to preserve the code formatting. As always, lot's of little things to help and learn along the way!
Controller board is a Board of Education USB 28803 using 3 Relays 27715 and a Ping sensor
Could you post a link to the YouTube video?
Just copy and paste the URL without any special tags. The forum software automatically embed the video.
The actual code required for the lights was very simple and involves having a small movement routine that tracked the few readings and compared them looking for a sustained change above a small threshold.
If there is movement:
Reload the countdown timer
If it is very close - turn on red light
If it is close but needs to come closer - turn on yellow light
If it is within parking distance (less than "too far away") - turn on green light
If it is too far away - turn off lights (optional)
If there is no movement and timer <> 0
Countdown timer
If timer = 0 then turn off the lights
