Write a code using 3 pins instead of 4 for ultrasonic 28015 and esp32 — Parallax Forums
Hello, I am using ultrasonic 28015 and esp32 to measure distance, but the ultrasonic has only 3 pins, +5V, ground, and sig. I wrote code as having trig and echo and put two wires in the sig, but it did not work. So, can some please tell me what should I change in my code to make it work??
https://ibb.co/YN0LjCQ
https://ibb.co/JnD5WhX
This is my code
// defines pins number
const int trigPin = 2;
const int echoPin = 5;
// defines varibles
long duration;
int distance;
void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600); // Starts the serial communication
void loop() {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
[img][/img]
  • Beau SchwabeBeau Schwabe Posts: 6,547
    edited 2020-04-15 14:32
    Try making your Echo pin the same as your Trig pin. The Arduino should automatically switch the function of the pin from an Output to an Input when calling the command.
    Additionally look at the Parallax Manual for that sensor ,,, https://www.parallax.com/sites/default/files/downloads/28015-PING-Sensor-Product-Guide-v2.0.pdf
    In addition to making the trigPin = echoPin, you may also have to change or ADD to capture the beginning of the returned pulse vs. the end of the returned pulse...
    Option1:
    so that it reads ...
    duration = pulseIn(echoPin, LOW);
    Option2:
    duration1 = pulseIn(echoPin, HIGH);
    duration2 = pulseIn(echoPin, LOW);
    duration = duration2 - duration1;
