FlexGui P2ASM Local Labels — Parallax Forums
I'm using FlexGui with the __pasm directive to implement P2ASM.
__pasm {
Does FlexC allow local labels? I can't get it to work using either colon or dot notation.
  • Yes, FlexC allows local labels, using whatever form (colon or dot) is appropriate for the processor being compiled for (colon for P1, dot for P2). For example:
    #include <propeller2.h>
    __pasm {
    entry
        nop
    .somelocal
        dirnot #56
        waitx ##20_000_000
        jmp #.somelocal
    bar
    int main () {
       _cognew(&entry, 0);
       for(;;)
       return(0);
  • Thanks @ersmith.
  • @ersmith,
    Now local labels don't work. I get the following messages.
    "C:/tools/PropellerTools/flexgui/bin/fastspin" -2 -l -O1 -I "C:/Projects/Prop2Test/flexgui/include"  "C:/Projects/Prop2Posit/PositTest.c"
    Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2019 Total Spectrum Software Inc.
    Version 4.0.5 Compiled on: Dec 19 2019
    PositTest.c
    Posit32es2.p2asm:664: error: syntax error, unexpected constant
    Posit32es2.p2asm:672: error: syntax error, unexpected '.'
    Posit32es2.p2asm:676: error: syntax error, unexpected '.'
    child process exited abnormally
    Finished at Tue Jan 14 14:13:19 2020
    Code follows:
    659                     mov     temp1,#quire_msw
    660                     sets    .0,temp1
    661                     mov     cntr1,#16
    662                     mov     k_expA,#271
    663
    664     .0              mov     frac64Ah,#0 wz
    665             if_z    sub     temp1,#1
    666             if_z    sets    .0,temp1
    667             if_z    sub     k_expA,#32
    668             if_z    djnz    cntr1,#.0
    669
    670                     ' Copy next 2 words to frac64A l and x
    671
    672                     sets    .A1,temp1
    673                     sub     temp1,#1
    674                     sets    .2,temp1
    675
    676     .A1             mov     frac64Al,frac64Al
    677     .2              mov     frac64Ax,frac64Ax
  • Ah, I see: it doesn't like ".0" and ".2" (it wants the local labels to start with a letter or underscore). Does PNut allow local labels to start with a digit? I'd kind of be surprised if it does, those look like floating point numbers, but I'll go along with whatever Chip does.
  • MSwannMSwann Posts: 20
    edited 2020-01-14 22:55
    ersmith wrote: »
    I changed all labels to DOT-ALPHA. Here are the results
    PositTest.c
    Posit32es2.p2asm:660: error: syntax error, unexpected '.'
    Posit32es2.p2asm:664: error: syntax error, unexpected '.'
    Posit32es2.p2asm:666: error: syntax error, unexpected '.'
    Posit32es2.p2asm:668: error: syntax error, unexpected '.'
    Posit32es2.p2asm:674: error: syntax error, unexpected '.'
    Finished at Tue Jan 14 14:47:03 2020
    Code follows:
    660                     sets    .A,temp1
    661                     mov     cntr1,#16
    662                     mov     k_expA,#271
    663
    664     .A              mov     frac64Ah,#0 wz
    666             if_z    sets    .A,temp1
    668             if_z    djnz    cntr1,#.A
    669
    671
    672                     sets    .B,temp1
    673                     sub     temp1,#1
    674                     sets    .C,temp1
    675
    676     .B              mov     frac64Al,frac64Al
    677     .C              mov     frac64Ax,frac64Ax
  • Something weird is definitely going on, I was sure that I compiled and ran the program I posted earlier, but now I can't. I must have mixed up compiler versions or something. Sorry about that, I'll look into it. There must be a conflict between the C parser and the Spin parser in __pasm blocks.
  • OK, the bug seems to be in handling any single character local label in C code in P2 mode; a little specific and I missed it. Basically local labels have to start with two letters or underscores to be properly recognized in fastspin 4.0.x. It'll be fixed in 4.1.0.
