Propeller IDE failure to download
rikkirikki Posts: 53
edited 2019-12-04 - 12:23:07 in General Discussion
Are there instructions on the site to facilitate troubleshooting when Propeller IDE fails to download?
I have searched, but I've found nothing.
I am using Propeller IDE ver 0.33.3, in Ubuntu Linux, with a Prop Plug.
My code is a minimal snippet used only to verify downloading:
OBJ
pst : "Parallax Serial Terminal" ' import serial utilities
PUB mainLoop
CON
' enable use of the external clock/crystal
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
When I click the WRITE (download) button, the dialog opens for a couple seconds, then declares "Download failed", then the dialog closes.
  • Does Propeller IDE find your com-port correctly ?
    And is the com-port available (I mean, to make sure the comp-port is NOT open in some other application).
    It you have any other port-consuming software open (such as Terminal, SimpleIDE, etc...), try closing all those, and then re-start Propeller IDE, and try again. IF Propeller IDE has a com-port dropdown to choose the port, make sure you've got the right one selected.
  • Also, for linux, make sure you've got permissions set for Propeller IDE to access the com ports (dial in group ?)
  • rikkirikki Posts: 53
    edited 2019-12-04 - 14:06:59
    VonSzarvas wrote: »
    Thank you, VonSzarvas for your response.
    The com port does appear in the Propeller IDE.
    If I unplug the Prop Plug, the listing for ttyUSB0 does not appear.
    When the Prop Plug is plugged into a USB port, it does appear in Propeller IDE.
    VonSzarvas wrote: »
    I (my user-name) am included in the dialout group.
  • Is there a "how-to" or "Getting Started" document which describe the procedures for downloading, with troubleshooting guide or suggestions?
  • I'm not aware of any such document for Propeller IDE.
    The other thing this could be is faulty target hardware, faulty USB cable, or un-powered target hardware.
    They would be some quick things to trouble shoot.
    1. Try a different USB cable.
    2. Make sure the target hardware (not the prop-plug, but whatever you are plugging that into) is powered up.
    3. Make sure the target hardware has the tx/rx pins the right way round, and that the RESn pin is connected too.
    OK... I realise in asking all this that we missed the first obvious question... What are you plugging the prop-plug into ? Can you share a photo or schematic if that's a non-Parallax board?
    Another thing you could try is putting a jumper wire between the PropPlug tx and rx pins, and then open a linux serial terminal, type some characters, and see if those characters echo back again. That won't prove that the RESn pin is working, but it will at least prove that linux is communicating with the PropPlug data lines ok. That said... this seems like it could be a target-hardware issue more than a PropPlug issue.
    edited 2019-12-04 - 18:29:28
    Thank you much for that information.
    I am connected via the Prop Plug to a Propeller Spinerette.
    I apologize that I had not posted that previously.
    The Spinerette is powered ok.
    I did verify that the Prop Plug is connected correctly.
    VonSzarvas wrote: »
    Thank you also for this suggestion.
    I will give it a try as soon as possible and post the results.
    edited 2019-12-04 - 22:02:51
    With a jumper on the Prop Plug from the Tx terminal to the Rx terminal,
    I can write into the terminal $ echo "1" > /dev/ttytUSB0
    With no jumper, the blue LED on the Prop Plug flashes.
    With the jumper in place, the blue and the red LEDs flash.
    I have not managed to get a terminal open as yet.
    I will do so and repeat.
    I especially appreciate and value your time.
    I appreciate your suggestion, which would not have occured to me to do.
    Noted in my journal.
    If I can get a good take on the required procedures and info then I'll publish it here.
    Somewhere there is a logfile, or can be.
    I will search for it and include what I see from PropellerIDE connection events to that interface.
    ETA: I'm not too concerned with the Spinerette. I only wanted a quickie simple time-of-day/season thing for some lighting.
    I have also a Project Board and a Mini, only not at hand for the moment. I'll get them in-hand and try also with the Mini if need be, and the Project Board.
    I'm convinced that purchasing a Project Board to mod for use as a downloader /terminal adapter is something I want to do. Worth it I think.
    I was connecting/downloading successfully to the Prop product 14 months ago.
    Just gotta document the solutions to development connectivity.
    I've clock-calendar 'breakout boards' to be integrated with the Project Board or Mini when/if needed.
    I just want to get on with that - clock-calendar functions on any of those products. Whichever gets me there first.
    -I don't know anything about the rtcc on the Spinerette, though I did download all the manufacturer's docs.
    -the rtcc breakout-boards I purchased are well documented..
    I'm just as yet ignorant of the libraries' integration in the Prop.
  • The spinerette has a jumper connecting or disconnecting /reset.
    it has to be connected for programming.
    maybe that?
  • msrobots wrote: »
    maybe that?
    Yes it is, thank you for suggesting it.
    The pgm enable jumper at J2 (the programming plug port)
    is in place.
    Added also to checklist.
    thanks for your input.
    edited 2019-12-04 - 22:38:17
    Success..
    I downloaded a flash routine from somewhere on the site.
    The downloader reports success.
    It isn't flashing the LED, but I can go from there.
    If it reports successful download, OK..
    I had only opened the Propeller ide terminal and got lines of ^.
    Seem to recall that's probably incorrect baud rate set somewhere? (it's been almost 2 years for me)
    The Terminal window will lock up if I open it to change the baud-rate... hm?
    '____CODE:________
    OBJ
    CON
    PUB LedOnOff
    dira[23] := 1
    repeat
    outa[23] := 1
    waitcnt(clkfreq/2 + cnt)
    outa[23] := 0
    edited 2019-12-04 - 22:41:38
    This is an interesting data-point:
    I ran propelleride from the terminal/command-line and a successful download produces this report:
    ( I know this is from Propman. I plan to learn to run a binary directly, as a test procedure.)
    note the report of a "Device Not Found" error.. in a successful download.
    I assume the Prop forces a disconnect after a download?
    It seems to report the same on a successful download and on a not-successful download:
    _____________dump from propelleride_____________________
    propeller.manager: opening "ttyUSB0"
    propeller.manager: attaching PropellerSession(0x171b570) to "ttyUSB0"
    propeller.manager: detaching PropellerSession(0x171b570) from "ttyUSB0"
    [PropellerManager] ttyUSB0: Downloading image (1156 bytes, 5740 ms)
    [PropellerManager] ttyUSB0: ERROR: Device not found
    propeller.manager: closing "ttyUSB0"
  • So your using the old spinnerete web server. Maybe the board is bad. Try using the propeller spin tool and ID hardware F7
  • J3 enable program jumper on spinnerete board
    edited 2019-12-04 - 22:48:38
    Except I closed that terminal, tried it from the user desktop.
    It failed.
    Closed that and opened another terminal.
    ran $ sudo propelleride and it ran again,
    but failed the download now also.
    Back up the chain..
    Tried once again inputing: $ echo "1" > /dev/ttyUSB0
    No problem, the red LED flashes for 1/4 second.
    Again opened $ sudo propelleride
    and it fails to download.
    There is no other program or service competing with Propman for that interface.
  • For the 32203 spinneret web server there are some spin files such as Webcam Demo etc.
  • Have you reviewed the old user guide
  • Eh, I do have the Spinerette user guide.
    May have missed something..
    As soon as traffic is less, I'll go after my Mini and Project Board.
    It is downloading ok now, however.
    I commented-out most of the code except
    PUB LedOnOff
    Now it downloads fine.
    Didn't report an error before other than "download failed".
    That's ok though. Now I know.
  • And now not ok.
    Perhaps a unit-swap will tell me something here... the tools aren't.
    edited 2019-12-14 - 22:55:57
    Sorry for failing to update (urgent family matters).
    I can report that my problem seems to be either the Spinerette or the Prop Plug
    (I had downloaded to the Spinerette successfully a year ago, don't know what changed )
    I am able to download OK to a Propeller Project Board from my present Propeller IDE setup/configuration.
    To do: Test the Prop Plug. Try downloading to a Propeller Mini.
  • Are you downloading to the internal RAM or the EEPROM? If it’s the EEPROM that you are downloading to, then it may have broken down somehow??
    Sarcasm for English build 2019.12.30 released two days before New Year's! Ports to other languages are in progress and are expected to be finished by January 5, 2020.
    edited 2019-12-16 - 12:25:14
    Thanks for that.
    The answer is, I do not know.
    Didn't think of it at all.
    I've had my Parallax products for almost two years and have not been able to immerse myself in them yet.
    That process has been interrupted each time I've made a start at it.
    This recent exercise to download test code to the Spinerette was the most recent run at it, and now I'm interrupted again (due to family medical emergency).
    So I had forgotten there was any option to download to either RAM or EEPROM.
    I do appreciate you bringing it to my awareness.
    I'll take another look with that in mind.
    Thanks for responding.
  • 2019-12-29
    Again, I regret that I'm as yet not able to add any additional value to this thread.
    When I know more then I do expect to update here, to try for a more comprehensive solution.
  • Try testing SimpleIDE with your PropMini as soon as you can get ahold of it. That will either confirm or deny the working status of the PropPlug.
