Getting encoder ticks from a DHB-10 motor controller
in Robotics
Hopefully someone can point me to a place in the documentation that I've missed.
I have the motor mount and wheel kits on an Arlo base and the encoders are connected to a DHB-10 motor controller. Somewhere I read that you can pull the encoder "ticks" from the motor controller board. Does anyone know how to do that?
Thanks for your reply and a DIST command sounds like what I need. However, I have gone over the DHB-10 motor controller documentation and I cannot, for the life of me, find any way to send commands to it or to receive responses from it. There doesn't seem to be a COM port or USB port on the board.
Could you please tell me how you were able to use the DIST command with a DHB-10 motor controller?
Doug
The easiest way to communicate with DHB-10 is with an Activity Board-WX.
http://learn.parallax.com/tutorials/robot/arlo/arlo-activity-board-brain
All the C libraries and programs are available at the Learn web site. They use SimpleIDE available from the Parallax web site:
https://www.parallax.com/downloads/propeller-p8x32a-software
You may be able to use the Parallax Serial Terminal to communicate on CH1, but I have not tried it.
Summary:
* Connect your uC's UART Tx pin to the white pin of the DHB-10's CH1 port.
* Connect your uC's UART Rx pin to the white pin of the DHB-10's CH2 port.
* Make sure that your uC and the DHB-10 share a common ground. The black pins on the CH1/CH2 ports are ground.
* Send "TXPIN CH2\r" to switch DHB-10 from half-duplex serial on CH1 to full-duplex on CH1/CH2.
