4 Channel Triac Driver
MacGeek117MacGeek117 Posts: 747
edited 2018-10-22 - 22:41:25 in Propeller 1
Hello all,
Would someone who is far better at assembly than me and has a little free time be willing to write a driver object for a 4-channel triac light dimmer such as this: https://www.amazon.com/dp/B06Y1W12XC/ref=cm_sw_r_cp_api_CgLZBbA3M6GN7 ?
One sync pin for all channels, and separate opto pin per channel.
Thanks!
Will post the project the object will be used in once it’s complete.
  • I wrote a 4-channel AC dimmer object for the EFX-TEK FC-4+. This should give you something to start with.
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
  • That definitely looks like it will do the trick.
    If I’m reading the code correctly, it auto-determines both Hz and whether the pulse is positive or negative?
    Thank you, sir!
  • It detects frequency, but is expecting a high-going pulse at zero-cross.
    Jon McPhalen
    Hollywood, CA
  • Perfect
    Thank you again
