EtPhoneHome v1.0 - A Nokia 6150(like) pcb redone with two propellers. PCD8544 l
Clock LoopClock Loop Posts: 1,604
edited 2018-01-18 - 09:20:13 in Customer Projects
This is EtPhoneHome v1.0
It is a nokia model 6150 (or like that has pcd8544 display in it)
The phone was slightly modified to remove the conductive rubber on the inside shell housing to prevent direct shorts on the new pcb.
The pcb houses two propeller chips powered from a 3.3v regulator that draws its power from the original phone battery.
(the prop might be able to run on the batterys raw voltage of 4v, i'll try it if someone asks.)
This platform does NOT have a charging circuit, I use an unmodified WORKING 6150 to recharge my batteries.
IT is a barebones circuit with prototyping areas on it. The prop is programmed from a header at the bottom which connects to the prop plug.
The second prop on the pcb is pretty much open for custom use, and is programmed using prop 1 with an internal binary.
Prop 1 programs and runs prop 2.
There is no wireless communications, but one could be added to the pcb via the prototyping holes and pin access.
TERMS OF USE: MIT License
"Permission is hereby granted, free of charge, to any pers...........................
..............................OMITTED FOR FORUM...............................................
.................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
The dsp/fpga king is dead, long live the prop.
Post Edited (Clock Loop) : 8/5/2010 11:08:35 AM GMT
1.Silicon gel filled square. <-2.Sonics(ultra even). 3.Lazers. 4.?
https://hackaday.io/project/162734-a-trillion-year-clock
54 propeller chips connected, One to rule them all.
https://forums.parallax.com/discussion/127983/55-parallax-propeller-s-parallells-processing-of-permanent-perturbations/p1
Seriously contemplating removing ALL my content from the net completely, FREEDOM OF SPEECH IS DEAD.
