ROSSerial implementation
in Propeller 1
Hello,
Is it possible to implement the ROSSerial in SimpleIDE, just like it is implemetent for the Arduino?
I have tried it myself, but i always get the following error, and i do not know how to avoid that.
It would be great if it is possible.
Kind regards,
Bert Berrevoets.
/opt/parallax/lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld: lmm/arlobot_core.elf section `.text' will not fit in region `hub' /opt/parallax/lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld: region `hub' overflowed by 93384 bytes
Kind regards,
Bert Berrevoets.
However, you might try a shorter string to see if it a string length issue.
