Set tempo for "Play a" block
John Kauffman
Is there a way to assign a beats per minute to duration values in a set of "Play a" blocks?
John Kauffman
Could you use the play tone block and use the duration to achieve the same thing? For instance, at 120 BPM, each beat would be 500 ms (1/2 second)? This could make a very interesting lesson in math and music. The block could be used for rests (or with a wait block).
See this great resource at wiki - https://en.wikipedia.org/wiki/Tempo
But for play block, having a duration doesn't have a meaning in music without a tempo (or as the DJ's say: beats per minute). I don't know if it would be easy to have a block that sets tempo. I think there might be one in Scratch.
Here is something fun that could be Saved As to start a new bit of code or appended to code.
http://blockly.parallax.com/blockly/editor/blocklyc.jsp?project=15299#
Sometimes brute force is a fine solution.
BlocklyProp Code for S3 - BPM Set and Volume Set for S3 Play Tone Block - http://blockly.parallax.com/blockly/editor/blocklyc.jsp?project=15299
