Finding out how much space is left in a PASM cog
Dear all,
I am looking for a quick method to determine how much local RAM is still available in a PASM cog.
Is there a more effective way than manually decrementing the "FIT X" parameter, starting from X=496 until a compiler warning shows up?
Thank you!
  • The BST has a compiler-listing window which shows the number of free longs in a cog. Open the window then compile to see this,
    you have to wade through the output.
  • If you are using PropTool, after compiling, put the cursor on the last variable name and it's cog address will be shown in the status line in yellow
  • Thanks!
