connecting Propeller to the world with Cellular
                    I have been developing my project by using the propeller and the Motorola c168i cellphone as described by jay Licklider a few years back.  I have come upon two problems.  the first is that it runs on the ATT 2G network that ATT is doing away with at the end of the year.  Secondly, and most importantly, I sent to deploy the project today.  While my LTE Verizon phone has great service, my ATT phone has none.
What are you guys using for a 3G solution? What networks are you guys running them on?
thanks
thanks
Adafruit now sells a 3G Fona. I think there are less expensive versions but Adafruit is really good about providing documentation and code examples.
TACHYON [~ \ \ FONA Celullar Routines \ A small module that sends SMS texts messages on AdaFruit's FONA GMS Module using a TING Account Card \ -------------------------------------------------------------------------------------------------------------------------- \ USAGE \ FONA.GO --- use this to init the module, start the RX form FONA module Task, hardcoded COG 7 \ FONA.STOP --- stop the task with this \ FONA.READ --- use this to read the FONA module return buffer to console, call by main module keypoll... \ FONA.SEND ( " text message to send" " 1234561111" -- ) send SMS message, results can be read with FONA.READ \ to the console or revectored \ -------------------------------------------------------------------------------------------------------------------------- \ dp 20151227-1900 V0.1 \ dp 20151228-1200 V0.2 got sms sending and reading \ dp 20151229-2200 V0.3 rewrote commands using strings, paramaterized SEND \ dp 20160906-1700 v0.4 added commands, tried to compile and run with Juno but no joy, stable on 2.4 hum? \ dp 20160907-1300 v0.5 debugging routines, work in progress \ dp 20160907-2030 v0.6 small module to integrate with gardencontrol \ dp 20160909-0930 v0.7 added start stop routines: gofona stopfona to control the RX task FONA.TASK \ dp 20160909-0930 v0.8 minor bug fix \ dp 20160910-2330 v1.0 rewrote controlling words in object syntax and documented usage, fixed FONA.READ dropped nulls FORGET FONA.fth pub FONA.fth PRINT" FONA Test V1.0 dp 20160910-2330 " ; --- setup, pins #9600 SERBAUD --- nice and slow #P2 == TX --- my pin, device RX #P20 == RX --- my pin, device TX --- vars LONG ?fona --- task flag --- serial task rx stuff WORD rxrd,rxwr --- create receive buffer, indexes #64 == rxsize rxsize BYTES buf232 10 LONGS stack232 \ Buffer data from the RS232 port - nothing else pub FONA.TASK stack232 SP! !SP \ init data stack to 0, assign stack to this task #9600 SERBAUD \ how fast are we going rxrd W~ rxwr W~ buf232 rxsize ERASE \ clear rxrd, rxwr and erase buf232 BEGIN \ run loop until ?fona false RX SERIN rxwr W@ \ get serial byte, fetch rxwr buf232 index( -- 0 datadr ) rxsize 1- AND buf232 + C! \ compute buf232 addr and write data to buffer rxwr W++ \ increment buffer pointer ?fona @ UNTIL ; \ You can read the buffered data with this pub GET232 ( -- ch|0 ) rxrd W@ rxsize 1- AND rxwr W@ rxsize 1- AND <> \ compute if the buffer is empty IF rxrd W@ rxsize 1- AND buf232 + C@ rxrd W++ ELSE 0 THEN ; --- redirect routine pub celpout ( char -- ) TX SEROUT ; --- redirect output to fona pub CELP ' celpout uemit W! ; pub cmrdchr ( char -- ) --- read sms message by index char --- AT+CMGR CELP --- send msg cmd " AT+CMGR=" PRINT$ EMIT CR CON ; \ Read Fona TX to the console pub FONA.READ ( -- ) --- read the fona and output GET232 --- display DUP 0= IF DROP ELSE EMIT THEN --- don't tie up console with nulls ; pub CRST CELP " ATZ" PRINT$ CR CON ; pub CBAT ( -- bat_status) --- show battery status 1|0 charging , % bat, millivolts 0, 67, 3890 CELP " AT+CBC" PRINT$ CR CON ; pub CECH ( ON|OFF -- ) --- set echo CELP IF "1" ELSE "0" THEN " ATE" PRINT$ EMIT CR CON ; pub CNUM ( -- ) --- request device number CELP " AT+CNUM" PRINT$ CR CON ; pub CPWR ( -- ) --- request device number CELP " AT+CPOWD=1" PRINT$ CR CON ; pub CTXT ( -- ) --- set sms command mode to text CELP --- set text mode " AT+CMGF=1" PRINT$ CR 100 ms CON ; pub CPDU ( -- ) --- set sms command mode to pdu CELP --- set pdu mode " AT+CMGF=0" PRINT$ CR 100 ms CON ; pub CDELA ( -- ) --- delete all messages CPDU --- set into pdu mode CELP " AT+CMGDA=6" PRINT$ CR CON ; pub FONA.SEND ( " message" " number" -- ) --- send sms message CTXT --- set into text mode --- Write Command 1) If text mode (+CMGF=1): +CMGS=<da>[, <toda>] <CR>text is entered <ctrl-Z/ESC> CELP --- revector TX pin " AT+CMGS=" PRINT$ --- send msg cmd 34 EMIT PRINT$ 34 EMIT --- send the destination address CR #500 ms --- wait for reply PRINT$ --- send the message ^Z EMIT CR --- end message CON --- back to CONsole ; --- This routine starts the system pub FONA.GO OFF ?fona ! --- set task flag to run ." Starting FONA Module " CR ' FONA.TASK 7 RUN --- start the rs232 task #500 ms CR ." Reset FONA: " CRST #500 ms --- delay CR ." Echo Off: " OFF CECH --- command echo off fona 10 ms CR ." Text Mode: " CTXT --- set into text mode ; pub FONA.STOP ." Stopping FONA Module" CR ON ?fona ! --- set task flag to stop ; ]~ ENDIn preparing to port Adafruit's Fona Arduino library to Spin, I wrote a program to monitor the communication between the Arduino and the Fona. This program is titled "MonitorFona.spin." Here's a link to the GitHub repository. If you want to use the program, download the archive "MonitorFona - Archive [Date 2015.06.06 Time 19.46].zip."
I had a hard time deciphering the datasheet of the cell phone module used in the Fona. Monitoring the communication between the Arduino and the Fona helped me to see exactly which characters were being used in the various commands and requests.
I think the program could be used to eavesdrop on any two devices using asynchronous serial communication including the 3G Fona.
Edit: I just noticed I included an example of the output from the program. The file "CapturedData150606a.txt" contains this example output.
Here's a portion of the output where I had entered the character "b" to request battery information. (This request was entered in the Arduino's terminal window.)
The "FromTerm" and "ToTerm" identifiers correspond with the communication lines between the Arduino and the PC. The "ToTerm" output would show up in the Arduino's terminal window. I used the program Parallax Serial Terminal.exe to display the output from the Propeller.
Of course the program isn't very useful if you don't have an Arduino.
It worked fairly well.
Thre are many break out boards. Only delicate thing is power supply (you have very high current peaks, but it's a common problem).
There also is a recent thread on SIM900 and data connection )I have never been able to handle data reliably, so I relied on SMS only)
http://forums.parallax.com/discussion/149716/sim-900-gsm-module-interface-object-wip
http://forums.parallax.com/discussion/164580/issue-gprs-sim-900
Massimo
