Different VGA background color.
So I am working with this VGA adapter and for some reason cannot find how to change the background color from blue, which it defaults to, to black. I have found plenty for Spin but not C. So does anyone know?
    I don't think this is so much about the VGA Adapter as it is object or library you're using. Which one are you using?
    Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | Website | Twitter | Google+
  • I am using the vgatext.h library but I don't think it is in this library because I haven't found anything.
    Yeah, I don't think this particular library supports it as a parameter. It may be possible to customize the library itself if you're a proficient coder.
