Impact Sensor Issue, SOMEONE PLEASE HELP ASAP!
daveetheewaveedaveetheewavee Posts: 3
edited 2016-04-28 - 10:48:56 in Microcontrollers
Hello, I am making a program where by blowing into an impact sensor, I am able to turn on an off a fan & on and off a light, so fat I have came up with this code:
' {$STAMP BS2}
' {$PBASIC 2.5}
Impact PIN 0
#SELECT $STAMP
#CASE BS2, BS2E
DurAdj CON $100
#ENDSELECT
Capture CON 2000
i VAR Nib
Main:
DO
DEBUG CLS,
"what do you want me to do?", CR
PAUSE 1000
DEBUG "Ready?"
PAUSE 500
DEBUG "BLOW!", CR
COUNT Impact,(Capture */ DurAdj),i
DEBUG CR, "You blowed ", DEC i, " times", CR
IF i=2 THEN fo
IF i=3 THEN foff
PAUSE 3000
DEBUG "Blow to go again"
DO : LOOP UNTIL (Impact = 0)
LOOP
END
fo:
DEBUG "fan on"
RETURN
foff:
DEBUG "fan off"
RETURN
But I'm having an issue with the impact sensor, when I blow into it once, it would give me a value of 4 or 5, or if I blow into it twice, it was give me a value of like 13 or 14, I need help fixing this problem so that if I blow once, it will give me a value of one & if I blow twice, it will give me a value of two and so on & so forth
  • Hello, I am making a program where by blowing into an impact sensor, I am able to turn on an off a fan & on and off a light, so fat I have came up with this code:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    Impact PIN 0
    #SELECT $STAMP
    #CASE BS2, BS2E
    DurAdj CON $100
    #ENDSELECT
    Capture CON 2000
    i VAR Nib
    Main:
    DO
    DEBUG CLS,
    PAUSE 1000
    DEBUG "Ready?"
    PAUSE 500
    DEBUG "BLOW!", CR
    IF i=2 THEN fo
    IF i=3 THEN foff
    PAUSE 3000
    LOOP
    END
    fo:
    DEBUG "fan on"
    RETURN
    foff:
    DEBUG "fan off"
    RETURN
    Sorry Dave, but in general you have to use whatever output a sensor sends you. In this case you could compare the value to 8 or 9 and pass a 1 if the input is lower and 2 if it is higher.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
    I wouldn't use the COUNT command for this. It counts pulses within a fixed period of time, but it is entirely possible that when you're blowing into the sensor just once, you're triggering it multiple times. I would instead use a state-machine type of detection and then wait a small, but fixed amount of time before testing for a second input.
    Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | Website | Twitter | Google+
  • state
    So what kind of state-machine type should I use, like what do you recommend I do?
    You're basically just detecting that the sensor transitioned from the inactive state, to the active state and back before delaying to test for a second occurrence.
  • Which sensor are you using. Way back when I was working on a project for the micromedic competition I used the Pressure sensor that came with the kit to start and stop a servo. The code is in Spin but I can post it if it will help.
    Andy North
    My Index Page:
