samples
rjo__
in Propeller 2
I've been working with v6 and waiting for things to settle out... which seems to be happening very nicely.
While the rug-rat is napping, decided to upgrade everything to v7. In five minutes, I couldn't get serial working and my mods for NTSC don't work either.
If you have a simple sample of either of these, I would appreciate it.
Rich
Rich
The PINSETM instruction format has changed as follows That is probably the cause of your issues
Here's a sample of my current async tx code
Supposedly, I will have time to try this out tonight.
P2 is looking fabulous.
I assume that the only issue with the NTSC stuff is setting the NCO correctly.
Remember the DAC's are set using PINSETM as well.
