Help create the Spin Standard Library!
1235»
  • Progress Report
    So I think you guys are gonna like this one. I've checked in the new string functionality. Thanks, @Cluso99 for suggesting ASCII0_STREngine.spin as the foundation for a string library!
    char.type - string char functions ( isUpper, isLower, etc.)
    string - core string operations (like copy, append, etc.)
    string.type - string type tests (like isUpper, isLower, etc.)
    string.float - convert between floating point numbers and strings
    string.integer - convert between integer numbers and strings
    The string.spin API has been cleaned up a lot.
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/string.spin
    PUB Append(destination, source)
    PUB Compare(str1, str2, casesensitive)
    PUB Copy(destination, source)
    PUB EndsWith(str, substr) | end
    PUB Fill(str, char)
    PUB Find(str, substr)
    PUB FindChar(str, char)
    PUB IsEmpty(str)
    PUB Left(destination, source, count)
    PUB Lower(str)
    PUB Mid(destination, source, start, count)
    PUB Replace(str, substr, newsubstr)
    PUB ReplaceAll(str, substr, newsubstr)
    PUB ReplaceChar(str, char, newchar)
    PUB ReplaceAllChars(str, char, newchar)
    PUB Right(destination, source, count)
    PUB StartsWith(str, substr)
    PUB Strip(str)
    PUB Tokenize(str)
    PUB Upper(str)
    char.type and string.type offer information about characters and strings respectively.
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/char.type.spin
    PUB IsAlphaNumeric(c)
    PUB IsAlpha(c)
    PUB IsDigit(c)
    PUB IsLower(c)
    PUB IsUpper(c)
    PUB IsSpace(c)
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/string.type.spin
    PUB IsAlphaNumeric(str)
    PUB IsAlpha(str)
    PUB IsDigit(str)
    PUB IsLower(str)
    PUB IsUpper(str)
    PUB IsSpace(str)
    Then I added a bunch of new demos!
    Append.spin
    LeftMidRight.spin
    Replace.spin
    Tokenize.spin
    UpperLower.spin
    I also added the Basic template, which is based on Simple_Spin_template.spin (thanks, @MikeDYur!).
    templates/Basic.spin
    Let me know what you guys think, and come on, people! Keep those suggestions coming!
    LameStation, the game console parents want their kids to play!
    PropellerIDE, an integrated, cross-platform IDE for the Propeller
    PropellerManager, an event-driven C++ API for managing Propeller devices
  • Brett Weir wrote: »
    Progress Report
    PUB Fill(str, char)
    PUB IsEmpty(str)
    PUB Lower(str)
    PUB Strip(str)
    PUB Tokenize(str)
    PUB Upper(str)
    PUB IsAlpha(c)
    PUB IsDigit(c)
    PUB IsLower(c)
    PUB IsUpper(c)
    PUB IsSpace(c)
    PUB IsAlpha(str)
    PUB IsDigit(str)
    PUB IsLower(str)
    PUB IsUpper(str)
    PUB IsSpace(str)
    Append.spin
    LeftMidRight.spin
    Replace.spin
    Tokenize.spin
    UpperLower.spin
    This looks excellent!
  • I agree with Betz, very nice!
    One suggestion: the "IsSpace" method makes me wonder if it checks for a single space, multiple spaces or any amount of whitespace (tabs, newlines, etc). If it only checks for a single character, it might be helpful to add another method for checking if a string is empty or contains only whitespace.
    David
    PropWare: C++ HAL (Hardware Abstraction Layer) for PropGCC; Robust build system using CMake; Integrated Simple Library, libpropeller, and libPropelleruino (Arduino port); Instructions for Eclipse and JetBrain's CLion; Example projects; Doxygen documentation
    CI Server: http://david.zemon.name:8111/?guest=1
  • Any plans to make the root directory a category only? there is going to be a lot here eventually, might be less cluttered.
  • David Betz wrote: »
    DavidZemon wrote: »
    Thanks, guys!
    DavidZemon wrote: »
    So there are two separate type objects; one for chars and one for strings.
    • Calling char.type.IsSpace would tell you if a single character is whitespace.
    • Calling string.type.IsSpace would tell you if an entire string consists only of whitespace.
    MikeDYur wrote: »
    The problem here is that Spin has never allowed subdirectories. I have a proposal that I've been working on to incorporate this feature in a way that's backwards-compatible with existing Spin products, but since I am working around it anyway, it is low on my priority list.
    DavidZemon wrote: »
    Makes sense. I'd just rename them to IsWhitespace then, since "Space" is a bit ambiguous.
    David
    Don't mind me, I control my world from a smart phone. I do have a question, I loose all formatting when I copy and paste code, and that is a pain, not sure there is any way around that, except to use a PC.
    _mike
  • Tracy AllenTracy Allen Posts: 6,335
    edited 2016-01-07 - 23:32:24
    I've been lurking this thread, but haven't had much time recently to step outside my cave. There was mention of the Gold Standard on page #1. It seems to be hard to find online, not on the Parallax site anyway. No-one had provided a link, but I just ran across a copy on a disk here, find attached.
    I found many of the suggestions quite reasonable for the sake of consistency and have been trying to follow them. So what if it flopped as an initiative. I'm not sure why, but I always feel there is yet another half-way step before any object qualifies as gold. That is to say, always tinkering.
    Brett, good luck with this initiative, the whole library, not merely individual objects.
  • DavidZemon wrote: »
    Brett Weir wrote: »
    DavidZemon wrote: »
    One suggestion the "IsSp" method makes me wonder if it checks forefersingle space, multiple spaces or any amount of whitespace (tabs, newlines, etc). If it only checks for a single character, it might be helpful to add another method for checking if a string is empty or contains only whitespace.
    Ahh, I'll leave it as is. A lot of languages have standard libraries with a similarly named function. It's not really ambiguous when you consider how trivial a function that detects an actual "space" character is.
    return (x == " ")
    I suspect that if someone actually needed IsSpace(), they would be doing text processing and already know what they're looking for.
  • MikeDYur wrote: »
    Brett Weir wrote: »
    _mike
    Hi there. I'm not sure if this is in response to what I said or not, because it sounds like a general forum question. Anyway that's what the code tags are for (added a space so it'd show up).
    [code][ /code]
  • I've been lurking this thread, but haven't had much time recently to step outside my cave. There was mention of the Gold Standard on page #1. It seems to be hard to find online, not on the Parallax site anyway. No-one had provided a link, but I just ran across a copy on a disk here, find attached.
    Haha, yes, of course, there is always room for improvement and more things to add. But as @potatohead mentioned earlier in this topic, the main goal here is the basics. Having a solid foundation of core objects that is widely applicable to other projects makes all Propeller programmers more productive. In doing this, we can enable developers to knock out a new application quickly instead of floundering in low-level details.
    Because who among us hasn't felt that frustration when you just can't find the library you need when you need it? And who among us hasn't been pleasantly surprised to find that a function you need is actually built-in to the language? That's a good feeling, and one I'd like to recreate with Spin.
  • Sorry Brett, my problem is just an Android problem, the github site is fantastic, and everday your work is making it better, don't know what I will use next for a descriptive. Below is what I am dealing with, there must be an app for that.
    DON'T USE.SPIN
    Filename: Author: Copyright (c) 2015 See end of file for terms of use.
    }CON    _clkmode = xtal1 + pll16x    _xinfreq = 5_000_000VAROBJPUBPRIDAT{
    TERMS OF USE: MIT License Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
  • MikeDYur wrote: »
    DON'T USE.SPIN
    Thanks! =P
    Ahhh! I see what's going on. This is one of a few issues that comes from making Spin cross-platform. Every operating system handles line endings differently, and every text editor handles them differently too. Some text editors automatically convert line endings but others don't.
    Most of Spin's lifetime has seen most Spin files being saved in UTF-16 little-endian with Windows line endings, because PropTool was written at a time when that was more common. PropellerIDE, on the other hand currently converts all files to UTF-8 with UNIX line endings for consistency, which is fine for the most part, but this will for example, make Windows Notepad not like it, while Wordpad will read it without a problem.
    Unfortunately, this problem is much bigger than PropellerIDE and there isn't much I can do. There are trade-offs in every solution. My recommendation is to try opening it on a computer, or wait until PropellerIDE has Android support (planned, but you could be waiting awhile). =P
  • Thanks Brett,
    I got a good idea of what you were talking about, the technical is over my head, I usually avoided spin files in OBEX for that reason, I know I'm in a very small minority that doesn't have home internet, and if I wanted dish satellite again, I could solve it.
    For now I'll struggle along downloading compressed archive's, or spin's I really want that have to gone over, or take one of my laptops to McD's, guess what's for breakfast.
    _mike
  • So @Cluso99, I've been thinking about this "rendezvous point" thing some more, and I think if the location wasn't hard-coded and was something rendered at compile-time, I wouldn't have a problem including it. Can you tell me more about how it would work?
  • Cluso99Cluso99 Posts: 14,913
    edited 2016-01-09 - 04:07:23
    Brett,
    Just a little busy currently, so this is short.
    You predefine a few longs in hub. Usually fixed, but doesn't have to be.
    In the main program you include two stub objects, stdout and stdin. Your program always outputs to the stdout, and always inputs from the stdin.
    Before using these though, you start (load) up cog(s) with the actual driver object, passing it the rendezvous location(s) in PAR. In the pcsio object, this is done simply by calling the pcsio.start(inRendezvous, outRendezvous, serPins, baud) pcsio is a modified serial object similar to FullDuplexSerial.
    If you are using separate drivers such as keyboard and tv, your main program just calls kbd.start(inRendezvous, pins+etc) and also tv.start(outRedezvous, pins+etc). This starts 2 cogs, one for kbd and one for tv.
    Stdin & Stdout only support the very basic char routine and test to see if there is a char available. Any higher level calls should preferably be done via a string/hex/decimal object to convert to the char out.
    The Stdin & Stdout routines each use one long rendezvous location in hub. $0 signifies empty ($100 is used for char $0), and asingle char is passed in the rendezvous long. ie we really only use 9 bits, but it allows for future expansion if required.
    Here is the stdout routine
    VAR
      long  pRENDEZVOUS
    PUB start(rendezvous)
      pRENDEZVOUS := rendezvous                             'get rendezvous location
    PUB out(c)
    '' Print a character
      c |= $100   '0.FF -> 100..1FF                         'add bit9=1 (allows $00 to be passed)
      repeat while long[pRENDEZVOUS]                        'wait for mailbox to be empty (=$0)
      long[pRENDEZVOUS] := c                                'place in mailbox for driver to act on
    And here is the stdin routine
    VAR
      long  pRENDEZVOUS                                     'stores a pointer to the hub mailbox
    PUB in : c
    '' Wait for an input character
      repeat until c := long[pRendezvous]                   'wait until the mailbox has a character
      long[pRendezvous]~                                    'clear the mailbox
      c &= $FF                      '$100 -> $00            'extract lower 8 bits (byte)
    PUB peek
    '' Returns a 0 if the buffer is empty,
    '' else next character (+$100) but doesn't remove from the buffer.
    '' The user routine must extract the 8 bits as the whole long is passed.
      return long[pRendezvous]                              'return ALL bits (long) in the mailbox
    This is the start of the pcsio driver
    CON
      RX1FIFO_SIZE = 160    '640 bytes
      TX1FIFO_SIZE = 160    '640 bytes
    VAR
      long  cog                     'cog flag/id
      long  params[4]               'for passing parameters
    PUB start(inRENDEZVOUS, outRENDEZVOUS, serPins, baud)
    '' Start Serial driver - starts a cog if necessary
    '' returns cog+1 if it had to start a cog, false if cog was already running.
    '' serPins = rxPin << 8 | txPin
    '' baud    = baud
      long[outRENDEZVOUS] := 4                              'Ping Ser Driver
      waitcnt(clkfreq>>2+cnt)
      if long[outRENDEZVOUS] == 0
        return False                                        'is alive
    'else start driver
      long[inRENDEZVOUS]  := 0                              'clear the rendezvous locations
      long[outRENDEZVOUS] := ">"
      params[0] := inRENDEZVOUS                             'pass the parameters
      params[1] := outRENDEZVOUS
      params[2] := serPins
      params[3] := clkfreq / baud
      cog := cognew(@entry, @params) + 1                    'Start the cog
      repeat while long[outRENDEZVOUS]                      'wait until cleared (ok to go)
      return cog                                            'cog+1 (=0=false if failed)
    DAT
                        ORG     0
    ' Initialisation.
    entry               mov     t1,par              'get the address of the parameter list
                        rdlong  rx1ptr,t1           'inRENDEZVOUS
                        add     t1,#4
                        rdlong  tx1ptr,t1           'outRENDEZVOUS
                        add     t1,#4
                        rdlong  t2,t1               'serPins
                        test    t2,#$80       wz    'if $FF, disable tx
    Website: www.clusos.com
  • @Cluso99, wow, that's actually not too bad. I think I'll do some experimenting today to see how this could fit into what's there.
    It's becoming more important to have this as I've been implementing some more complex terminal interfaces that would be impractical to make them work for different outputs and still be drop-in solutions. This could solve a lot of problems.
    Yup. It's a good idea. :-)
  • tonyp12tonyp12 Posts: 1,940
    edited 2016-01-10 - 00:38:58
    string tokenize for me is to find a token and replace that with zero, so when you forward this string-pointer it will be this shorter zero-terminated string.
    It's destructive, but as all strings are in sram on a Prop it will always work and you could always put the token back if needed.
    strtok() (that is what it's called in C string library) is great for parsing.
    So it should be: PUB Tokenize(str,str)
    http://www.tutorialspoint.com/c_standard_library/c_function_strtok.htm
  • tonyp12 wrote: »
    Ahh, good point. I had kept it spaces only because I wasn't sure how to go about implementing one that supports full tokens, but now that you mention it, it deserves a second look. I'll see what I can do about that when I get back to it later.
    tonyp12 wrote: »
    It also should be noted that the replace functions do not currently shrink/expand the strings they operate on, so that's another issue that needs to be resolved that may impact this one.
  • Progress Report
    Hi guys, I've been quiet for a couple of days because I've been working on an object I've wanted for a long time. =P
    I've created a new object called commandparser for building command line interfaces with Spin. It depends only on the string library so it can be used to create serial, TV, and LCD interfaces. It also supports multiple commands so you can easily make a terminal that feels like a regular shell. Check it out here:
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/commandparser.spin
    And read the documentation for it here:
    http://lamestation.net/downloads/misc/docview_demo.html
    This is made better because the terminal now implements a ReadLine function that allows backspace.
    You will also notice the formatting of this html file. This is a demo of the documentation view that will eventually find its way into PropellerIDE, so start using markdown for your doc comments now!
    I created an object called debug.shell which I'd like to become a drop-in debug terminal. Right now, I've merged in Chip's Monitor.spin to print hex data dumps and also added a clock info printout, but any suggestions or code to contribute to this object would be awesome!
    Check it out here:
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/debug.shell.spin
    Here it is in action:
    $ hex -l 10
    0000  00 B4 C4 04 6F 86 10 00 F8 0F 08 15 3C 01 10 15  ....o.......<...
    0010  E8 02 06 04 2C 01 04 00 73 01 04 00 DC 01 0C 00  ....,...s.......
    0020  6D 02 00 00 CE 02 00 00 E8 02 C8 00 D8 06 E8 01  m...............
    0030  04 0B C0 04 E8 0D C4 04 24 20 00 54 68 69 73 20  ........$ .This
    0040  73 68 65 6C 6C 20 65 6E 61 62 6C 65 73 20 61 6E  shell enables an
    0050  20 69 6E 74 65 72 66 61 63 65 20 74 6F 20 61 20   interface to a
    0060  6C 69 76 65 20 50 72 6F 70 65 6C 6C 65 72 20 66  live Propeller f
    0070  6F 72 20 64 65 62 75 67 67 69 6E 67 2E 00 68 65  or debugging..he
    0080  6C 70 00 68 65 78 00 6F 75 74 70 75 74 20 63 6F  lp.hex.output co
    0090  6E 74 65 6E 74 73 20 6F 66 20 6D 65 6D 6F 72 79  ntents of memory
    The combination of these new objects and the improved terminal in PropellerIDE make for the most shell-like experience I've ever had on a Propeller, and it makes the next IDE feature I should add fairly obvious: a command history!
    To see the new command line parser and the debug shell in action, download the latest version of PropellerIDE (just released moments ago) and try out the debug.shell.spin object.
    http://developer.parallax.com/propelleride/
    I haven't heard any new suggestions for objects recently, so keep them coming, add your own, and let me know what you think!
  • avsa242avsa242 Posts: 141
    edited 2016-02-14 - 16:11:30
    Brett,
    I just stumbled on this after searching for the source of the library that used to be (I think?) part of the propelleride git repository. It looks like a fantastic idea, and I really like what I've seen so far, personally.
    One thing I haven't seen anyone address yet, maybe because it doesn't seem to be a problem at least with the objects in the library so far, is capitalization of filenames: this is an issue that can be a real pain on OS's/filesystems that are case-sensitive, because not everyone has the same idea of how filenames should be capitalized. If I remember rightly, I think I brought this up as an issue on propelleride's old issue tracker a long time ago, not really thinking it through - something to the effect of asking if propelleride could be case-preserving, but also case-insensitive. I believe the answer was that if other languages or editors (e.g., C) don't do this, why should propelleride? And indeed, after thinking about it, I agree 100%. The issue still has a potential to exist, though, so it's left more as habit of the programmers. I can't tell you how many times I've downloaded a propeller archive that had source with a line like
    ser: "FullDuplexSerial"
    but the file stored in the archive is capitalized like fullduplexserial.spin, or similar - it's just frustrating to have to fix in order to build it. What are your thoughts on mandating that source in this repository be made a consistent case, say, all-lowercase, for example?
    Regardless, whatever you decide, thanks so much for all your work on this and propelleride!
    Cheers,
    Jesse
    EDIT: Sorry, I hadn't seen CONTRIBUTING.md when I posted this *hides in shame in the corner*
    WIP Spin drivers for various devices: LSM9DS1 IMU (SPI) | Newhaven 4x20 OLED (I2C) | MLX90621 (I2C) | SHT3x (I2C) | SSD1306 OLED (I2C; P1-SPIN, P2-SPIN2) | TCS3x7x (I2C) | MAX31856 (SPI) | BMP280 (I2C) | TMC2130 (SPI) | nRF24L01+ (SPI) | MLX90614 (I2C) | MAX9744 (I2C) | DS28CM00 (I2C) | TSL2591 (I2C) | CC1101 (SPI) | SX1231 (SPI)
  • avsa242 wrote: »
    Brett,
    Cheers,
    Jesse
    Haha, thanks for the feedback. I'm just happy to hear that someone else is frustrated by the same problem. :)
  • MikeDYur wrote: »
    I think this is a time saver!
    I just saved it to my desktop. I'm going to add PST because I frequently use it to develop code.
    Larry
    If the grass is greener on the other side...it's time to water your lawn.
  • lardom wrote: »
    MikeDYur wrote: »
    PST functionality is available in the com.serial.terminal object (though it may be renamed to terminal once a rendezvous driver is available).
    https://github.com/parallaxinc/spin-standard-library/blob/master/library/com.serial.terminal.spin
    The primary difference between PST and com.serial.terminal is that com.serial.terminal factors out the core serial and string formatting functionality into reusable objects, which can reduce the code size of projects that leverage these library objects.
  • Hi Bret,
    I just found this thread, and I can't wait until I can download and play with the library.
    Jim
  • I tried running the test.sh that comes with the library, and got a number of errors. It looks like the tests may have bit-rotted?
    openspin -L . ./library/sensor.inductive.spin
    Propeller Spin/PASM Compiler 'OpenSpin' (c)2012-2013 Parallax Inc. DBA Parallax Semiconductor.
    Compiled on Mar  2 2014 11:49:29
    Compiling...
    |-signal.synth.spin
    |-signal.adc.spin
    |-display.tv.graphics.spin
    |-misc.numbers.spin
    misc.numbers.spin : error : Can not find/open file.
    openspin -L . ./library/demos/misc/COIL_demo.spin
    Compiling...
    |-display.tv.spin
    display.tv.spin : error : Can not find/open file.
    openspin -L . ./library/demos/math/rctime/RCTIME_background_DEMO.spin
    Compiling...
    |-display.tv.spin
    openspin -L . ./library/demos/math/rctime/RCTIME_foreground_DEMO.spin
    Compiling...
    |-display.tv.spin
    openspin -L . ./library/demos/system/ClockDemo.spin
    Compiling...
    |-system.clock.spin
    system.clock.spin : error : Can not find/open file.
    openspin -L . ./library/demos/sensor/Inductor Demo.spin
    Compiling...
    |-display.tv.spin
    openspin -L . ./library/misc.coilread.spin
    Compiling...
    |-system.clock.spin
  • ersmith wrote: »
    Compiling...
    |-signal.synth.spin
    |-signal.adc.spin
    |-misc.numbers.spin
    Compiling...
    |-display.tv.spin
    Compiling...
    |-display.tv.spin
    Compiling...
    |-display.tv.spin
    Compiling...
    |-system.clock.spin
    Compiling...
    |-display.tv.spin
    Compiling...
    |-system.clock.spin
    Ahh, well, I guess you could say that. This is all a work-in-progress, so I may have changed the names of some objects without updating their demos. I'm releasing a new product in a few months and this effort is a part of that, so everything in due time. =P
