Welcome to the Parallax Discussion Forums, sign-up to participate.
'Shared smartpin example - 4 cogs using 1 serial transmitter
baudrate = 115_200
tx_pin = 62
dat org
pinsetm a_serial8,#tx_pin 'setup smartpin
pinsetx bitclkz,#tx_pin 'set baudrate
setb dirb,#tx_pin 'enable smartpin
loc adra,#mycode
setq ##20_000_000 'start delay (1/4 sec)
coginit #1,adra 'launch cog
setq ##40_000_000 'start delay (1/2 sec)
coginit #2,adra 'launch cog
setq ##60_000_000 'start delay (3/4 sec)
coginit #3,adra 'launch cog
.loop waitx ##80_000_000 'wait 1 sec
pinsety #"A",#tx_pin 'send "A" character
jmp #.loop
bitclkz long 80_000_000 / baudrate
a_serial8 long %1_00_11100_0000_0000_00_0_0000000000000
orgh $400
org
mycode waitx ptra 'get start delay in ptra
cogid adra
add adra,#"A" 'generate test chracter
pinsety adra,#tx_pin 'send character
jmp #.loop
What if you add random waitcnts in your loop? Does it still do the same thing? Or does it get misconfigured or confused or locked up or something else bad?
Depends on what you want to protect against ?
Present Prop has 'free for all' on Pins, so an errant COG can crash any pin it likes.
Certainly, there could be merit in a safer mode, where outside code cannot take down a system, but that level of sophistication may be too much for P2 ?
I think that means you also lock items like PLL, and any other global-access critical control registers.
No lockup or invalid characters but as expected random output. (BCDBCDBACDBCDBCDBDCBDC)
I assume some chracaters were lost along the way.
A note in the doc's is propbaly all that is needed in the end.
Yes, I need to outline limitations.
All cogs can simultaneously do PINGETZ on the same pin, but PINSETx/PINACK to the same pin cannot be from multiple cogs at once.
Can multiple COGS can interleave access, viz any time the channel is not busy with another COG ?
A caution in the documentation leaves the impossible as a possible achievement with the P2.
Propellerheads like to achieve the impossible!!
