Phase Detection with Modulated Return Signals?
I have (2) applications which require generating an audio frequency reference signal (<=500hz, one is digital, the other sinusoidal), then measuring the phase shift on the returned signal after external processing (both return sinusiodal). I have successfully used Beau Schwabe's PhaseDetector object with an unmodulated reference. However, in actual use, the returning signals will include the processed reference mixed with voice, music or "weak RF" audio noise. Equivalent hardware-based solutions often include active op-amp and switched capacitor filters. Is there an easier way with the Propeller? I'm not familiar enough with filter theory to apply some of the software filters described in the forums (or to know if they're even appropriate). Any assistance would appreciated.
dt is the sampling interval in system clocks.
For more details about quadrature mixers, see this thread:
-Gary
